Rough Runner! CE Light=Diagnosis HELP needed
Old 10-10-2004, 08:19 AM
amorphous's Avatar
Hey guys....
took my 3.4l equipped runner camping and wheeling yesterday....no water, nothing into the engine compartment....and heading to the campgrounds the engine started running rough crusing along at 55-60 in 4th gear...before a downshift...at about 2400-2500 rpm - but, if you gave it gas, it would take out like a kicked mule... ....however...this a.m. it's gotten a bit worse...so here I am at my mom's house 70 miles from home....
my plan of action:
spark plugs - I've never done 'em...figure start there AND
CLEAN THE MAF! And wires to follow if the plugs don't do the trick (and just to do them too...)
other than that....I've put a can of Lucas gas treatment in the tank....and ... I NEED SUGGESTIONS!
i know that the stealership could help me w/ the computer diganosis of the o2 sensor, etc....but...it's SUNDAY.
thanks in advance!
Åaron
Old 10-10-2004, 09:06 AM
User 051420's Avatar
Was your CEL flashing at any point?
I had a real bad misfire. Plugs and wires did the trick!
Old 10-10-2004, 10:40 AM
Johnboy's Avatar
noob question= whats a MAF and how do you clean it
Old 10-10-2004, 11:07 AM
amorphous's Avatar
THAT's it....i hope this does the trick....now....off to GAP my "pre-gapped" bosch plugs.....yeesh!
Å
Old 10-10-2004, 11:11 AM
amorphous's Avatar
oh yeah....john boy....maf= mass airflow sensor....
you clean with electrical contact cleaner! search it ...you'll find a TON of ˟˟˟˟!
ä
Old 10-10-2004, 02:49 PM
amorphous's Avatar
ok...it's fixed!
Plugs, wires and a MAF cleaning (which I *don't* think it was a dirty MAF)
I'm kinda kicking myself....shoulda done this before now...but....
anyway, looks like the wires were ORG! (they have 1997 ink'd on them, and the truck is a '98 built in 10/97!)
and....IIRC, I've read this in a thread somewhere.....
passenger side were NGK....driver side were DENSO! WTF!???!?
but....worried mind at ease!
Å
Old 10-10-2004, 02:52 PM
Good luck with the Bosch plugs. A lot of members seem to have problems with them. Glad to hear you're up and running again.
Old 10-10-2004, 03:20 PM
Johnboy's Avatar
ä
aight dude thanks
Old 10-10-2004, 04:11 PM
Mikey's Avatar
My suggestin would be to go back in and get those Bousch out of there. I never liked any of their plugs. I always use the stockers!
Old 10-10-2004, 06:41 PM
amorphous's Avatar
ok....so....the ride home.....
(test drive was FINE)
going up hills at about 80 mph (crusie control) when the 4r dwnshftd to 2nd, at about 3.5-4k rpms.....it would start to sound rough....nothing like before....but similar....then the CEL would flash for a bit.....then it would go away. AH! This happened on every BIG hill....thank God I'm not in the MTNS!
so, STILL a BIT of misfire....nothing like before....but....yeah....I'm thinking the Bosch's are going to go BYE BYE and I'm going to spend the money on 'yota partz from the stealership.
Å
Old 10-11-2004, 04:14 PM
amorphous's Avatar
crap! it's BACK! CEL and all....i've got an appt at the stealership tomorrow for a code check.....$60! ah well....at least then I'll know where the problem is......
suggestions???
Å
Yont283
09-23-2022 08:06 PM
Alex Bessinger
06-28-2015 10:05 AM
shredder4286
06-27-2015 09:42 AM
ACZR
06-23-2015 07:55 PM
94hiluxZE
06-22-2015 10:42 AM
Quick Reply: Rough Runner! CE Light=Diagnosis HELP needed
