rough idleing
Old 08-09-2004, 08:40 AM
surftaz's Avatar
rough idleing
Hello,
I have a 97 sr5 4 runner.
It has 135Kon it, It just started to idle roughly, I cleaned the Mass air flow, the air box and tube, I have replaced the spark plugs, the Fuel filter and it still seem to idle poorly,
Any suggestions? Can the catylic converter mess up the idle, my converter seems to smeel a lot more than it did,
Thanks,
Surftaz
Old 08-09-2004, 11:11 AM
rimpainter.com's Avatar
Give us a little more description...
does the engine have a timed shudder? Is it just a distant vibration? Is it a miss?
Take a dollar bill and hold it up to your exhaust pipe while the motor is idling, hold it about 1/4 inch from the pipe. If you have a miss, it will pop the dollar bill. Let us know what you find out.
Old 08-09-2004, 03:24 PM
MTL_4runner's Avatar
Use some carb cleaner and an old toothbrush to clean your throttle body.
The TB is the most common cause for poor idle.
If you have a clogged converter the performance of the truck at highway would be lacking all power.
Old 08-09-2004, 04:33 PM
evilcow's Avatar
Have you checked the PCV valve? Also check for vacum hose crack's/leaks.
Sleaker
08-26-2020 06:03 AM
Eggslinger
06-08-2019 03:32 PM
1992pickupSr5
05-09-2019 08:44 AM
TACOJO
11-27-2015 05:26 PM
markwink
08-18-2015 12:38 PM
Quick Reply: rough idleing
