Rough idle, cel at 60+km/h
Old 02-26-2013, 11:36 AM
OJ Simpson 4Runner's Avatar
1998 4runner sr5, not sure what is going on here but it started to idle really rough after warming up. once its warmed up, the acceleration is horribly rough, and once i go near 60km and higher, a cell flashes on and off. also if i let go of the gas peddle, it stays at that exact speed i was going without dropping down at all. its revving kinda high in park and neutral as well
New plugs, new wires, maf is clean, timing belt is still good. i dont think there are any vacuum leaks... any ideas??? This only happens once the car is driven for like 2-3 minutes. the first few minutes it drives fine.
I am guessing it has something to do with a sensor or air intake? if it was sparkplugs or wires, wouldnt the initial start up be rough? which it isnt.
Old 02-26-2013, 02:10 PM
98SR54RUNNER's Avatar
TPS? Injector? What's the CEL?
Old 02-26-2013, 04:35 PM
dont have a code reader. what would cause a car to have a rough idle, jerking when creeping forward or reverse and the inability to decelerate!?
Old 02-26-2013, 05:18 PM
If you can get it to an auto-parts store, many will scan and tell you the code for free. Many stores will "rent" you the scanner for free also. I don't know enough to make an accurate prediction based upon your description. It'd be easier to go off the stored codes that have been thrown.
Old 02-28-2013, 09:03 AM
I gave in and took it to a family friend's shop. Turns out coil pack was dead, misfire on cyl 4. also 3 belts were cracking. UGH.
Old 02-28-2013, 10:10 AM
Damn. Yeah I bet he pulled the codes and immediately saw misfire on that cyl. At that point it's either the coil pack or injector. Probably time to get into the shop though if your drive belts were cracking. Relatively cheap fix though, glad it wasn't anything serious.
Sleaker
08-26-2020 06:03 AM
Eggslinger
06-08-2019 03:32 PM
1992pickupSr5
05-09-2019 08:44 AM
256mbaker
07-31-2015 06:45 PM
v_man
07-23-2015 04:01 PM
Quick Reply: Rough idle, cel at 60+km/h
