Rotor removal on a 1999 4 Runner
Hi guys!
I have searched the Forums but can't find the exact info I am looking for. I have a 1999 4Runner SR5 V6. I am trying to replace the front Rotors due to some mild warpage. I can't seem to get them off, and am not sure how to do it. Are they the "fall off" kind, or are they like the 96s where I have to remove the whole hub?
Any ideas?
Thanks in advance!
btw, I am going to be selling it asap if anyone may be interested. I will post a message about that later.
Any ideas?
Thanks in advance!
Yeah they are the pop off type. Once you removed the caliper the rotor should come off. If it doesn't come right off, persuade it a little bit with a hammer and that should knock the rust loose that's probably holding it.
Thanks for the quick response man!!
I guess I should have stated that I did remove the Calipers already!
I have been persuading them with a rubber mallet quite a bit. I also squirted them a lot with WD-40 behind them where they mount. Still no joy.
I wanted to check with you fellas to make sure they come off before I REALLY start to put the muscle down on them and end up breaking something ya know?
voiddweller
19
05-02-2016 09:10 PM
YotaGreenhorn
06-27-2015 07:00 AM
