roof rack help mod
roof rack help mod
I went camping this weekend and took a few friends needless to say it was a tight ride. what is the best way to do a roof rack mod?
Originally Posted by Mossback74
Do you have a factory rack? if so, buy a rack and put it on. If not, buy yakima or thule towers and add rack. I prefer a small gear trailer for camping.
I bought some Yakima towers off a Yotatech member, then ordered some brand new crossbars for it.
The just mount in the door jamb and on the rain gutters. I think they work great. Would work better with a cargo basket though.
what part # are the towers. and how did you mount them?
Another vote for all Yakima gear.
http://www.pnw4runners.com/runs/41203/21.jpg
http://www.pnw4runners.com/runs/41203/8.jpg
And it can be highly modded.
https://www.yotatech.com/~corey/tech...mods/corey.htm
Corey thanks again, you are always so helpful.
Sound like a pretty cool guy.
Originally Posted by RobT2k
Anyone have any trouble with them not holding or ripping out due to weight?
Wow... someone mentioned my name... lol... *ears burning*
I'm using the factory rails that go from back to front with the factory square nuts that slide in there, (5 per side)
the only thing that annoyed me were the cost of metric stainless bolts... lol.
so far its still holding....
Is that what you used to attach to the square nuts? What is your rack made of?
That's what I planned on using also, what did you need the metric bolts for?
honestly the project was a bit more PITA then i had thought... would I do it again instead of buying a rack? definately, soo many ppl have complemented me on how they like the rack because it gives much more clearance... though i still stay away from parking garages... =)
you all have supplied good info but im still trying to do this without spending 150. on the parts for a rack. If I can get past the mounting issue I can make the rest. If im drilling mounts on the roof I want to get it right the first time if you all know what I mean.
I'm also looking at roof rack systems. It's been my understanding that if the vehicle (2nd generation 'Runner) doesn't have a factory roof rack then you'll have to drill. Is this correct? It sure would be nice to just mount it to the drainage track.
Ed
Ed
Just a heads up Yakima stuff is nice but it's also spendy. I probably have close to $500 in my towers, crossbars, locking cores, and basket.
Ed
Ed
If someone that has done theres could give model #s that would be the best. I've done a little searching but if you are looking for an older rack then its hard to cross reference to see if it will fit. I'm just looking for the towers, almost have all of the equipment for my welder so I can make my own rack that way I can install locks and such.
As long as you go with the tower option you won't have to drill. Mine didn't have a stock rack and I just used the towers. This should work for the older non Q-towers too. The towers are all the same it's the clips that are different for attaching them to a particular vehicle. Yakima's site will step you through what you need to mount a particular type of rack or accessory.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
TheBFA
02-15-2020 06:55 AM
Scotttekoch
09-28-2015 10:30 PM
