roof rack?
Old 09-24-2003, 05:53 PM
knemo77's Avatar
roof rack?
im looking at a thule roof rack basket systema dn im wondering if you had to buy the cross bars to install it or did you u-bolt it directly to you factory rack....2000 4runner.
my buddy can get it half off and i want to order one soon. so what install did you guys do to make this work? And will it stillaccept bikes?
thanks
Old 09-24-2003, 06:04 PM
waskillywabbit's Avatar
Re: roof rack?
thanks
I just bought one for my 2000 4Runner from www.rackattack.com. Use the THULE AUTOMATED FIT GUIDE place to design one custom for your rig and it'll tell you the equipment you need. You will need a pair of cross bars, some feet, the mouting kit and a fairing, and locks for the feet are optional but keep them from being taken off...aka stolen. They were having a 15% off sale when I bought mine 2 weeks ago.
Hope this helps!
Brian
Old 09-25-2003, 04:44 AM
Senior Member
jacksonpt's Avatar
Most thule stuff is setup to mount to either Thule bars or factory bars... I suspect (but don't know for sure) that the baskets will too. The down side to mounting to the factory crossbars is that they are not as sturdy as the Thule bars. This may or may not be an issue for you depending on what you plan on using the basket for.
Old 09-25-2003, 05:43 AM
hillbilly's Avatar
Thule's can be mounted either way depending on which setup you select. The Playpen (basket) mounted to the Thule load bars has a higher weight capacity and sits a little higher off the roof deck. Mounting to the OEM cross bars won't be a sturdy, as jacksonpt said, but is a bit cheaper.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
Redeth005
06-28-2018 08:16 PM
Scotttekoch
09-28-2015 10:30 PM
dguzzi
09-03-2015 08:48 AM
HaydenConQueso
07-12-2015 05:22 PM
Quick Reply: roof rack?
