Rolling Down Rear Window
I may be mistaken but shouldn't i be able to roll down the rear window using my key on my 1997 limited? I don't have the alarm/keyless feature for some dumb reason but shouldn't i still be able to roll it down at the rear hatch with the key?
you should be able to roll up the window when you lock your door from the tailgate. unlocking the tailgate should unroll your window.
if you are having problems, hold the key in one position (depending on if you are opening or closing the window) for about 4 seconds. It should work.
One thing I noticed...
If you have your 'window lock' on, the rear window (and of course, any other window except the drivers) will not open using the dash up/down button. Don't think this would effect you using the key on the exterior switch, but it might be worth a look?!?
jasonty
41
12-23-2018 01:00 PM
Yotadawgjr
10
08-23-2015 10:51 AM
DrZero
18
07-24-2015 11:31 PM
sabine
07-18-2015 03:59 PM
icentropy
07-14-2015 10:23 AM
