Rocker arm problems
Rocker arm problems
Well my idiot light didn't work and I ran my 22RE low on oil and now I'm having problems with my #3 & 4 exhaust rockers not getting any oil. I'm sure I'll have to replace them and the cam. This isn't the original engine in my 92 pickup so where do I look to fine numbers or identifying marks on the engine so I can be sure to get the right parts. Where is a good place to get parts? My local parts house says they're 31.95 each, that's a big chunk of change when you're talking about 8 rockers.
Any advice would be appreciated because I've never worked on a toyota before.
I seen an auction for them but I think it's ended, final bid was 92 bux.
I wasn't sure about using refurbished rockers with a new cam, would that be ok?
oh wait, I just re-read your post, are you talking about just the rockers or rocker assembly?
hmmm, all I found was this used assembly
I did a search in camshafts "22re"
if they're resurfaced i'd think they'd be fine.
all rockers are compatible between the 20R/22R/22RE but the '83-up 22R rockers are the best since they're aluminum rather than steel.
FS[SouthCent]: TX Third Gen UCA and LCA low miles Taco
KyleT
07-21-2015 07:54 PM
2002, 20r, 22re, adjustments, arm, arms, compatibility, costly, elnieves22, gbpec7, problems, resurface, resurfacing, rocker, toyota, tundras
