Rock Crawler Steelies Black Paint ?
Old 10-19-2004, 06:39 AM
flyAddict's Avatar
Question Rock Crawler Steelies Black Paint ?
My wheel weights got put on the outside of my nice new black steelies. I anyone's experience what black paint matches the powdercoat the closest? Semi Gloss or Gloss?
Old 10-19-2004, 07:25 AM
User 051420's Avatar
Better yet, have them balanced with the weight on the inside.
Old 10-19-2004, 07:27 AM
waskillywabbit's Avatar
Talking
Toyota Touch Up Paint Black #202
That is what I used. Works great. Easy to put on with the little brush. Bonds well. Never had to reapply.
My wheels had wheels weights all over the place, but you can't tell in this photo.
Old 10-19-2004, 07:29 AM
rimpainter.com's Avatar
Actually balancing on both sides does a much better job, especially on steel wheels which are notoriously out of balance from the factory. That being said, I recommend going with a semi-gloss to start, and if that does not match well, go with the gloss.
Good luck getting the paint to stick on those weights. For some reason, even prepped and primed the paint just does not want to bond.
Old 10-19-2004, 07:32 AM
When mine were balanced, they used the lead on the inside rim and stuck some flat sticky weights on the surface of the rim. Balanced perfectly. Roadforce.
Old 10-19-2004, 08:10 AM
You were one of the lucky ones I guess...
Old 10-21-2004, 06:23 AM
flyAddict's Avatar
thanks for the tip. My brother has the cragar version of the black steelies which have a red and blue pinstripe around the rim...he now hates it after seeing mine, so that should kill two bird with uno stone.
Old 10-21-2004, 06:34 AM
Mad Chemist's Avatar
Ahhh, the lovely "pride" stripe, heh? Brian, I'm not sure you're still allowed to post pics of a vehicle you don't own anymore...
malteserunner
Early Land Cruisers (Build-Up Section)
89
02-09-2018 06:59 AM
JookUpVandetti
09-11-2015 09:41 AM
Quick Reply: Rock Crawler Steelies Black Paint ?
