Rim width question?
Old 02-25-2005, 11:45 AM
Silver_Truck's Avatar
Rim width question?
I know this has been beaten many times, but couldn't find a definitive answer searching thorugh old threads. I'm going to go with a 32x11.5x15 bfg m/t for now and need to get new wheels. Will 15x8s work on these and not have a problem with the tire popping off when aired down? Also if I go to 33x12.5s in the future will I be able to keep the same rims and not have to worry about anything? Lastly what is the proper backspacing, would it be 3.75"?
Thanks and sorry for the stupid questions.
Geoff
Old 02-25-2005, 12:09 PM
Poopshute's Avatar
15x7's or 15x8's are usually ideal. I had some 15x9'2 or 10's when I ran 32's and they worked just fine. Hey, would you be interested in these?
$60+shipping or make me an offer. I believe they are 15x7's.
Old 02-25-2005, 12:21 PM
pinnacle's Avatar
I had 15x8's with BFG A/T's. I never had a problem with the bead popping off. I went down to 8psi and no problems.
Old 02-25-2005, 12:23 PM
There's actually a set of 15x7s here that I'm looking at getting for $60, that way I don't have to pay shipping. But I'm not sure if they're going to be wide enough or if I'll need 8's. Thanks tho I'll let you know if the other falls through.
Old 02-25-2005, 01:41 PM
rivercat's Avatar
i've got some 32x11.5's on 15x10's and i think the rim is to wide.... the lip sticks out some from the edge of the tread...15x8 would be better that's what my 33x12.5's are on, 32x11.5 you could run on stock rims maybe with spacers?
Old 02-25-2005, 01:55 PM
Poopshute's Avatar
No worries... I think I just found a buyer. But I would agree... 15x8's or 15x7's is what you need... no higher than 15x8.
Old 02-25-2005, 02:38 PM
k cool, what about 33x12.5s on 7" wide wheels? Is that ok or would I be better off on 8"
Old 02-25-2005, 03:37 PM
deathrunner's Avatar
I currently run 33x10.50's on 5x7 stock rims. I think it holds pretty tight when aired down. I would go with 7", it actually makes the tire taller than if you spread it out.
I ran these tires on 15x8's with no problems also.
I have run 33x12.50's on 12" rims (Previous owner did this. They were wide, but I would have gone 8's or 10's
chukarhunt
12-08-2019 11:39 AM
4x4-runner
12-27-2016 01:58 PM
4x4-runner
08-30-2015 08:55 AM
4x4-runner
08-02-2015 09:24 AM
TURBOrunnerNM
07-20-2015 08:31 AM
Quick Reply: Rim width question?
