Rim/Tire Size?
Old 01-23-2007, 10:07 PM
4Runnin96's Avatar
Rim/Tire Size?
I have a 96 2wd 4Runner and im trying to figure my tire options. I just put in a OME 3 inch lift and have a 1 inch body kit that is in my garage waiting to be put on. Anyways I have the stock 15x7 Rims now and was wondering what options I have when it comes to me buying new rims. I have a set of used Goodyear MTR 33x12.50/15 that I would like to use. Im going to go with the Rockcrawler 152 Black streetlock wheel but im not sure as to how much backspacing I need or what the difference is from a 15x8 and a 15x10. Any insight? thanks BTW, the sites awesome!!
Old 01-23-2007, 10:16 PM
Elton's Avatar
welcome to yotatech... a 15x8 will be fine
Old 01-24-2007, 10:24 AM
4Runnin96's Avatar
What about the back spacing? Someone told me that If I used the Steel rims that they would hit the calliper. Any truth beind that?
Old 01-24-2007, 01:16 PM
hiloracerboy84's Avatar
ur gonna have to try n put em on to see if they fit. some will some wont. i think with a 15x8 u might need less than 4.5" backspacing for the tires not to rub...maybe 4" bs. the calipers will either hit the lip on the inside of the rim or the face of the caliper will hit the mounting surface on the inside of the rim
Old 01-24-2007, 05:02 PM
wjwerdna's Avatar
well, ive never really compared, but it seems 15" rims and tires are more common/cheaper, if this is not the case or doesn't matter... a 16" won't hit the calipers
Old 01-24-2007, 05:16 PM
4unner4life's Avatar
I just put on some 33x12.50s on 15x8 rims(with 4" backspacing i believe) with a 2.5 to 3.5" suspension lift and 1" body lift. I rubbed a little on the pinchweld, but a few whacks with a hammer fixed that one. You may want to consider getting a body lift too, if you don't want to rub.
Old 01-24-2007, 05:46 PM
SoiledGreen98's Avatar
This is a good link.
http://www.rsracing.com/tech-wheel.html
smilen724
13
11-08-2015 04:11 PM
Gravel Maker
RuffStuff
10-04-2015 10:26 AM
oldblue
09-28-2015 04:07 PM
gp66
09-14-2015 12:10 AM
Gravel Maker
RuffStuff
09-08-2015 05:46 AM
Quick Reply: Rim/Tire Size?
