revtek
Old 12-30-2003, 07:26 AM
rugerm44's Avatar
revtek
Anyone have any dealings with a revtek lift kit on a tacoma.I installed an arb bumper and winch and I would like to lift it back up again.Thanks
Old 12-30-2003, 09:44 AM
RTdawgs's Avatar
ill suggest OME coils instead of spacers.
also, SEARCH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!
Old 12-30-2003, 09:48 AM
WATRD's Avatar
He can't... Search is BROKEN!
The first lift I had on mine was a Revtek. Not a bad lift, but for what you get, the Cornbred spacers are a better deal.
As was mentioned, with the kind of weight up front that you are talking about, better coils or coilovers will be a better bet. Once I put the ARB and winch on mine, the stock coils + Revtek combo sagged back down to stock height and I had some wicked coil bind.
Old 12-30-2003, 11:11 AM
1Runner's Avatar
ROB!!! You got your SAS done! (just noticed your avitar) Looks nice.....
So, corn is better than revtec? If I ever get around to doing anything to mine, I'll remember to check into them.
Old 12-30-2003, 11:30 AM
WATRD's Avatar
Yep, it's done Check out the thread in the trail reports section, it's got some photos and links to more The truck did very well
https://www.yotatech.com/forums/show...threadid=23037
Cornhole's kit is better on all fronts. It's cheaper, is better quality, doesn't rust and has AAL's for the rear instead of nasty blocks.
http://www.cornfedsuspension.com/
Old 12-30-2003, 04:34 PM
rugerm44's Avatar
coils
Sounds like with the revtek kit after a while I would be back where i started.I saw a set of 1.5 inch lift coil springs in Northwest off road catolog for 150.I also noticed downey off road has a coil over set with bilsteins thats adjustable.I just dont want to mess up the ride quality.Im not that interested in lifting it higher than stock.Just want it back level.Thanks for the info.
Old 12-30-2003, 05:11 PM
RTdawgs's Avatar
Re: coils
call ARB-USA and talk to them...they will tell you exactly what you need.
dont get spacers, youll kick yourself later.
tytataco4x497
04-25-2004 06:13 PM
cubuff4runner
10
12-03-2003 10:04 AM
ALBPM
7
09-27-2003 09:06 PM
Noden
07-31-2003 11:09 AM
atticus
05-24-2002 06:03 AM
Quick Reply: revtek
