| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Revo's 285/75R16
#2 (permalink) |
if you drive in a straight line the whole way!
![]() j/k I'm not sure about your problem, I'm guessing no, especially with the tjm that's probably sagging your front more than normally. but maybe someone else will have an answer for you. Pics of your rig? I wanna see if the tjm has affected your front height.
__________________
Rob |
#3 (permalink) | |
Super Moderator-Sponsoring Member
Staff
He'll be rubbing around the moutain when he comes...
Quote:
You put that big a tire on there with no lift at all and a TJM on the front to boot and you'll be starting a forest fire with all that friction when you try to turn.![]() Brian
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale |
#4 (permalink) |
Thats what I thought--Thanks for your help. I'll work on the pics.
#5 (permalink) |
Yes and no! If you plan to do fender trimming too, which you'll need to even with your lift, unless you plan to rub a bunch, then you can drive all day long with no lift and 285's, and the only place you'll rub is on the frame with the inside of the tire. I've done it! Check out this thread: http://www.yotatech.com/showthread.p...ender+trimming
Chris |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Factory Recommended Tire Pressure 285/75R16 BFG M/T | 4x4Fink | Tires & Wheels | 13 | 02-21-2007 08:24 PM |
| Four 285/75R16 BFG AT's | 4Peanut | The Classifieds GraveYard | 21 | 04-16-2006 09:40 AM |
