Reverse Lights quit working ?????
Old 09-22-2007, 06:41 PM
mokai's Avatar
The other day I noticed they quit ..Today I looked for a reverse fuse and can not find one..I checked the bulbs and connections and all seem fine..Anyone have an idea what it could be...Truck is in Sig...
Old 09-23-2007, 04:48 AM
mokai's Avatar
Anyone , could use some ideas here if you have um..
Old 09-23-2007, 06:21 AM
Sizzler's Avatar
I would be looking at the reverse switch located in the shifter area.
Old 09-23-2007, 07:08 AM
INFINITY's Avatar
check all the fuses to see if any are blown, tranny switch (continuity) and check cables (corrosion and oil contamination), check bulbs,
if all else fails just use a flashlight, haha
Old 09-23-2007, 11:40 AM
LuminoZ's Avatar
my backup light stopped working the other day too. I just pulled the wiring harness on the sensor tapped into the tranny. (I have a 5spd) and jumped it with a paper clip. When I started my taco up and the brake lights came on, I knew I just had a bad sensor...
Check the Guage fuse in your driver's side panel.
Old 09-23-2007, 03:45 PM
mokai's Avatar
Thanks for the replies..Ill take a look at the tranny switch..
06-01-2021 01:51 PM
gillesdetrail
11-19-2019 12:56 PM
camdenbuck
07-07-2015 07:33 AM
Jnkml
07-06-2015 01:20 PM
gog1968
06-22-2015 05:55 AM
Quick Reply: Reverse Lights quit working ?????
