Reverse lights not working? NEED HELP
Is it my reverse sensor or are my reverse lights just weak? Oh yeah I just recently rear ended someone. Does anyone know a good place where I can purchase a new front bumper for a decent price? oh yeah and umm front grill?
1991 4dr 4wd 4runner
Re: Reverse lights not working? NEED HELP
I really thought that both of them wouldn't be burned out at the same time -- and when I pulled them, just one was burned out. But when I replaced them both, they both started to work. Go figure.
If you already did, then it might be the switch but I'll wager it isn't.
Hi,
i'm having a similar problem with 1991 4Runner and my reverse lights don't turn on when I put the car in reverse. I have checked the fuses, checked the bulbs and all is fine. I also checked the reverse light switch and couldn't see anything there apart from the grease and dirt. so i cleaned it and re-connected the cables but still no luck.
any Ideas ?
any Ideas ?
Hi,
any Ideas ?
any Ideas ?
reverse light switch issues
i don't know what you mean by "jumpering the reverse light connector " ???
the other thing is, i'm not sure if it was the reverse light switch i cleaned. I guess the question is where do i find the reverse light switch on a 91 4Runner SR5 Limited (manual gearbox) ?
cheers,
cheers,
cheers,
cheers,
Likely somewhere close to the shifter/shift rails and will have wires and a connector.
06-01-2021 01:51 PM
Jnkml
07-06-2015 01:20 PM
Steezy96yota
07-06-2015 10:00 AM
