reuse lower fuel injector seals?
Old 01-22-2005, 04:57 PM
rivercat's Avatar
can i safely reuse the lower fuel injector seals on my 3.0? they had alot of build-up and grime in them, but i got them pretty clean, they don't look torn up at all and weren't leaking before i pulled the injectors as far as i know? i don't believe i got new seals in my kit.... would my best bet be to install the fuel rails and injectors and pressurize the system > check for leaks? thanks for your input -rowan
Old 01-22-2005, 05:17 PM
Yoda's Avatar
Hey Rowan,
North Bend Auto parts has 6 seal kits in stock. part # CRB 212080 list price $3.91 ea (?) 1 kit per injector.
The lower seals won't leak gas, they seal the intake from vacuum leak (be safe and replace them). While you had it apart would have been a good time to get the injectors ultrasonic cleaned and flow tested (But it does add to the cost of your repair, and I know your work is shut down for now).
Old 01-23-2005, 07:58 AM
Bigblock's Avatar
if you have new o-rings use em.put some oil on em so they slide in easy.
Old 01-23-2005, 04:20 PM
rivercat's Avatar
cool, if napa has them i'll do it to be safe...
Doug4320
03-24-2018 10:11 PM
09-04-2015 09:27 AM
88sasturbotoy
08-11-2015 01:56 AM
shisha1999
07-13-2015 11:09 PM
karbin
07-05-2015 11:37 PM
Quick Reply: reuse lower fuel injector seals?
