| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
return of the headliner rattle
__________________
My name is BILL not Bob Mazda3 :0( |
#2 (permalink) |
mine rattles also when it get hot, when its cold i guess it tightens up and dont make a sound i also have a friggin dash board rattle of somesort every since i smashed my bumber :wtf:
__________________
2002 4runner - Mods - Dynomax exhaust, Airbox/amsoil. Piaa Extreme White 2 inch driving lights, Nokian Vativas, mickey thompson wheels |
#3 (permalink) |
hey bob,
is it the entire headliner? or is it certain spots? have someone drive you around on a bumpy road and listen to where it is coming from. having taken my entire interior apart, there are only a few places that can really cause headliner squeaks. first, the area that the plastic interior contacts the headliner. second, the underside of the headliner and the metal roof. third, any of the contact points where the parts hold the headliner in place. http://www.4runners.org/articles/sound/headliner.html i have some headliner squeaking too but only on roads that have little, little bumps. on the freeway, its quieter than a library ('cept the damn mirrors). i'm going to remove my headliner sometime in june or july to see how the sound deadening is holding up. some type of thin, adhesive backed, soft foam or rubber material might be the trick. bob |
#4 (permalink) |
My headliner squeaks in the morning but it disappears after it warms up.
__________________
2002 4Runner SR5 |
#5 (permalink) |
There's no shaking mine, and it's really freaking annoying.
So, here's what I've taken to doing at the moment. 1)Had the wife drive me around while I listened for the squeak. It seemed to becoming from one predominant spot, so I folded some paper and slipped it between the headliner and the plastic interior parts. 2)As I still heard some noise, I've been putting one small section of paper up at a time. 3)At the moment, it's not to bad. It's pretty warm today, however, so I'm interested to see how it sounds tomorrow. Once I've pinpointed it, and hopefully this method is working, then I'm going to find something to put behind those sections where the headliner is touching the paneling. Hopefully that does it, because it makes me insane. I don't mind it when it happens occasionally, but it was literally a constant thing even while driving along the highway. Albeit my highways aren't probably as smooth and nice as Bob's CA highways. Bill
__________________
#6 (permalink) |
do you have a sunroof? i had the same problem, i just sprayed WD40 on sunroof track where body and plastic molding joins...just a shot in the dark, but fixed the problem and hasnt come back for a year...maybe you outta try that?
__________________
01 4runner 4x4 SE (stupid Cntr lock diff,VSC,TRAC) **Stuff I've wasted my money on** *front/rear chicken fence *clear corners *Hella 500s *Lexus HID *PIAA LED bulbs *ISR, Breather,DP Mod *Amsoil filter *husky cargo liner *Cobra STX II *SE badge *Griot's stuff* Alpine CDA-9815+Infinity Reference+12"Fosgate Punch/amp *BFG A/T 32s *Bilstein HD *Perforated Leather Seats...Buncha other stupid things "Uh....I dont know what I'm doing" -Ray http://community.webshots.com/user/ray0227 |
#7 (permalink) | |
Quote:
Mostly it's the headliner above the pillars. Day two of my cardboard is resulting in few noises, so I think I pinpointed it. Bill
__________________
#8 (permalink) |
Update:
I believe that it's the piece of metal that goes between the two sides that the dome light mounts to just behind the sunroof. Short of taking the headliner out, I'm having a hard time finding away to make this stop. I've stuffed some sponges up between the headliner and the bar, hoping that I could just permanently have it pushing up somehow, as pushing up on that piece of metal with the dome light out makes it stop. It's mostly on the passenger side, so I've ruled out the dome light wiring which I've heard makes noises as well. It's officially not a rattle though, it's a squeek, and with the sunroof trim taken off the headliner, it's even more noticeable. I will lick this yet...though I don't know how. It wouldn't bother me so much if it wasn't right abouve my damn head. Bill
__________________
#9 (permalink) |
Bob,
Heheh...Bill. ![]() I believe Wild Bill has a great pic on his website where he stuck foam between two water lines or something like that which is causing the squeak. Check out his site, bite the bullet, remove the headliner and take care of this problem! Bob |
#10 (permalink) | |
Thanks.
I licked this one a while back though. My rattle was the rear metal bar that runs between the two rails of the sunroof. I fixed it by removing all of the trim around the sunroof, moving both seats forward, putting on a pair of gloves, and hanging from said metal piece. I bent it, and it no longer makes the noise. It's a little ghetto, but I was able to drive with sanity, until the dash rattle returned. Bill Quote:
__________________
#11 (permalink) |
Super Moderator-Sponsoring Member
Staff
With all the rattles and things that go bump in the night in your 4Runner lately, me thinks it either is haunted or is truly falling apart!
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale |
#12 (permalink) | |
Quote:
Intermittent ones when you hit bumps, etc. and Ones that are constantly there regardless of terrain. You could be on the highway, and it could be smooth as glass, and they are still there. I deal with the first as it's a truck, but the second can be fixed somehow, and they make me want to tear my ears off. I'm very high strung. Bill
__________________
#13 (permalink) |
Bill,
I can relate. In early 2000 I purchased a new Subaru 2.5 RS coupe. The car was an utter joy to drive - power, AWD balance, braking, etc - but the amount of rattles in that thing were insane. After numerous trips to the dealer complaining of various rattles, I started pinpointing them myself. First was the sunroof. Take the interior cover out, fasten various pieces of foam to the metal sunroof, reinstall cover. Rattle fixed. Then came the glovebox rattle. Take glovebox apart, find that the little rubber bumpers seemed too small for the job and replaced them with larger ones. Rattle fixed. Lastly was an annoying buzzing/rattle that came from the rear seat area, over the passenger side tire. I had a neighbor drive me around for 30 minutes while I shoved my hand in numerous nooks and crannies. Took the entire interior out down to bare metal and tried to locate any area where plastics and metal could interfere. Insulated those with foam. Problem remained. Found myself so bloody pissed that I sold the car after a year and 36,000 miles. Had a super time in the snow though, spinning endless 360s with the great 50/50 manual tranny torque split... Andreas
__________________
2001 SR5 4Runner 4WD, Dorado Gold, 184,XXX miles 2007 Volvo XC 90 AWD V6, Silver 1995 Porsche 993, Polar Silver |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Wanna help me diagnose a headliner/A pillar rattle ? | nrgetic99 | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 05-08-2007 11:19 AM |
| Rattle in the headliner... | Texas_Ace | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 04-29-2007 08:31 PM |
| Got a rattle and more rattle...need the silence... | Ursa Americanus | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 10-15-2004 01:29 PM |
| Rattle in My Headliner | PutzRunner | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 10-05-2003 12:30 AM |
