replacing rear leaf springs on 1st gen
hi all, i've got a tech question for you. my buddy brought his '88 4runner over to my house this weekend in hopes of replacing rear leaf springs (i suggested add-a-leaf to get rid of the rear-end sag, but he was insistant on new springs). anyway, we couldn't get the bolt out of the spring. the nut came right off, but the bolt that holds the spring to the shakle woudn't slide out. we tried every tool we had, including the bfh (after spraying the bolts with anti-sieze stuff). does anybody know how to get these bolts out? what would a real mechanic who actually knows what they are doing do?
thanks!
thanks!
Well there's a sleeve inside the eye of the leafspring that the bolt is seized to. No mater what you do it won't come out unless you torch it out ,or use a sawzaw to cut inside the shackle(front or rear same thing). It's a hardened bolt so it will eat up the blades.
I went trou 5 blades on my sawzaw and was using a 5" cutoff wheel at the same time to get through the bolt by the gas tank. I torched out the other three. Once the bolts are out it's cake to replace the springs. I would heat the u-bolt nuts up also to cherry red to get them off. Good luck.
SAWZALL!!!
Mr. Milwaukee must be rolling over in his grave.
And no, I'm not actually mad. I'm perpetually thinking about adding a Kaymar shackle set to the rear of my 88 4Runner, but have yet to do it.
If you don't mind MikeD, could you link to or explain which add-a-leafs your friend is going with?
If I said reciprocating saw you might of been confused. Everybody seems to call them sawzaw around here , so I did to fit in.
Have I been zinged?
Actually, I get on my gf's dad's case all the time over calling his DeWalt a Sawzall.
I know what a reciprocating saw is.
edit: added to cut down on the likelihood that my post might seem snotty... also to talk in more ridiculous sentences.
as a side question....on the '88, the current leaf springs are good (i.e. not cracked or anything). my friend already spent the $70 at the junkyard for the new springs. would it be an ok idea to take one (the smallest) leaf from the new springs and use it as an add-a-leaf for the current pack. that way we don't need to mess with taking the current leafs out.
voiddweller
19
05-02-2016 09:10 PM
cchinny
06-25-2015 08:11 PM
dirtrider0129
10
06-24-2015 12:24 PM
