Replacing Limited Rear V6 99 Inner Oil Seals Rear Axles
This seems to be a very common job, and lots of write ups. The one I intend to follow is very well written, Replacing Rear Inner Oil Seals On Toyota Rear Axles
https://www.yotatech.com/~corey/tech...m1_oilseal.htm
However I got a few questions that no one has addressed.
Do I need to drain the trans oil out first? If not, won't all the oil flow out from the axel as soon as I pull it.
If I don't need to drain it, then will mixing the Valvoline High-Performance 80W-90 Gear Oil with the existing oil be bad? How would I know how much to add back in there since some has leaked?
I see many pictures with the axle pulled and placed with the axle shaft standing. Will the brake shoes stay in place that way, or do I have to remove it?
Lastly after placing the new seal in the axle, do I need to bang it into place? Will pushing it all the way into the end suffice?
I appreciate all the help you can give me.
thanks!!
thanks!!
When's the last time you changed out the rear diff oil? Now could be a terrific time! Not necessary, but something to think about. Some oil will come out when you pull the axle, but not a whole lot. Do be prepared with a drain pan of some sort.
Brake shoes stay in place. Check to see they aren't contaminated with oil.
I froze my seal and put it in as straight as I could as far as it would go, then used a like-sized tool to carefully tap into place (socket, tranny bit, whatever I have).
The job isnt too hard. You dont have to drain the tranny fluid. Just the diff fluid. It smells nasty!! Invest in a good seal puller. I got mine at harbor freight and it broke. I ended up smashing teh seal to get it out. Take your time. Do not scratch the inner diameter of the axle where the seal sits.
which do you think is better?
http://www.sears.com/kd-tools-seal-p...p-00999814000P
or this
http://www.harborfreight.com/seal-puller-91352.html
I don't need to touch the ABS sensor right?
thanks!
Use the one from harbor freight. Also works great for pilot bearings, front wheel bearing seals, trans output seals and pinion seals. If you clamp off the brake line and only do one side at a time its much easier to bleed the brakes when you're done. Remove the abs sensor when installing the new seal. Makes it easier because the seal is metal and the sensor magnetic. To fill the diff when you're done: be sure the truck is level whether on the ground or in the air and fill through top hole until it just wants to overflow
the1998sr5
15
07-14-2020 08:35 PM
jerusry
10-19-2015 05:28 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
Iceman4193
07-15-2015 04:48 PM
