Replacing front CORNER lights!!!!
I popped up the hood and unscrewed the front left corner light housing but don't know where to go after that!!!! What do I do? Also how can I install new light bulbs in my center A/c dash? Probably easy procedures for most people but that's why i'm even involved in this forum. Someone help!!
I saw in your profile that it's a 91 4runner? this should help with the a/c light
https://www.yotatech.com/~corey/tech...ts/l33t35t.htm
just pull out on the housing, they are mounted with two screws towards the back and to bayonnet posts towards the front. if you unscrew ithe screws just far enough to come out of the mounting holes in the fender but still stay threaded in the housing you can pull on them real hard, it will pop out about .75'' and then you can stick your fingers in the front and pull it out entirely. its tricky the first time, you ust have to see ow it goes together, then its easy later on.
Re: Replacing front CORNER lights!!!!
http://www.4runners.org/articles/clears/
Hope this helps!
Brian
Hey It worked
Just want to say thanks to everyone who replied. It helped a lot!!! Now if anybody can give a step by step description on how to fix my sun roof. I can hear the motor running and sometimes it satys on track up until it's about to fully close or open
Aleeex_u
06-05-2016 06:52 PM
WTB[FourCorners]: 84-88 Toyota Pickup Doors with Auto Windows
subaruwrx88011
10-09-2015 12:39 PM
