replacing engine
Old May 27, 2005 | 02:20 PM
hektikwon's Avatar
replacing engine
I'm about to put an 88 3.0, auto tanny/transfer case in my 91 4runner. Is there any problems that I may run into? Also about how much downtime can I expect from this? It has 79k on it runs beautifully and only set me back about $900. Oh yeah I will probrably do the work my self.
Old May 27, 2005 | 05:10 PM
nunsa's Avatar
You'll match right up! The only probs you might find is the AC/emissions, other than the minor bs, it's a direct match!
How much DT depends on your mechanical ability, 2 days and you should have it! Like I said, it depends on your mechanical ability, tools...! Yeah, about 2 days for the average guy! If the 3.0 is already out of the donor vehicle, 2 - 3 days! Good Luck! If you need advice on the 3.0, PM me, I spent 6 yrs working on these beauts!
Harry
Old May 27, 2005 | 06:26 PM
trx125's Avatar
Total downtime for an engine swap about 5-7 hours depending on experience. I can take a motor out of one vechicle and swap it into another vehicle in about 4 hrs.
Old May 27, 2005 | 06:38 PM
cabbage's Avatar
Yup, dont know about the rules over in Georgia but here in CA you cant legally (unless the referee passes you) put a older engine in a newer body because the emission components are different.
Another rule is you can only put in an engine that was offered that year, so if you had a 88 22re you can put in a 22ret or 3.0.
Old May 27, 2005 | 10:33 PM
hektikwon's Avatar
ok so I will try this weekend. I'm pretty good mechanically so hopefully it won't be to bad. I heard Cali has some tough smog laws but here in GA it isn't bad at all. thanx for tha help.
Old May 29, 2005 | 02:27 AM
Greg'sToy's Avatar
the studs where the front exhaust pipe bolts to drivers side exhaust manifold can be a real biyatch. around here they are usually siezed and break. best to have a couple extra ones around if the pipe hasn't been off in years..
Old May 29, 2005 | 02:51 AM
Bigblock's Avatar
its a pretty tight fit to pull it all out together.i had to remove theT/C to get it back in,it also has a 3 inch body lift.
voiddweller
19
May 2, 2016 09:10 PM
Ichneumon
Sep 27, 2015 04:21 PM
Jmiller1023
23
Aug 6, 2015 07:03 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
