Replacing Clutch While Replacing Engine
Old 07-28-2009, 01:34 PM
flyfishmike's Avatar
Hello,
240k mile motor developed a rod knock. Buying a JDM motor to replace it. Still have original clutch. Obviously, will replace that at the same time. Will I need to remove tranny to replace the clutch, if the motor is removed? Or do you only need to remove the tranny for a clutch replacement if the motor is in place?
Also, any tips on what clutch to buy? Toyota OEM? I am not a serious off-road guy. Just need 4WD to get to the river to go fishing.
Thanks!
1998 Tacoma 4WD 2.7l
Old 07-28-2009, 04:07 PM
eric-the-red's Avatar
The clutch bolts to the back of the motor, on the flywheel. So just bolt the clutch to the new motor and install it. No need to remove the tranny.
Old 07-28-2009, 04:12 PM
That's what I thought. Thanks, Eric.
Any thoughts on what replacement clutch to buy?
Old 07-28-2009, 04:16 PM
noahrexion's Avatar
exedy
Old 07-29-2009, 09:23 AM
SnowRunner98's Avatar
I bought an advance auto stock replacement. and a new fly wheel at the same time.
voiddweller
19
05-02-2016 09:10 PM
Dillon1983
07-07-2015 06:47 PM
Mutinebullfrog
06-18-2015 01:36 PM
HBoss
12-20-2004 08:45 AM
peterbilt
07-18-2002 05:16 AM
Quick Reply: Replacing Clutch While Replacing Engine
