Replacing Cat on 02 Cali Model *SEARCHED*
hey again, ive spent days searching for the answer but to no avail. i have a 2002 4runner that is a cali emissions model (i.e. 2 cats). my truck had been running rich for awhile and i guess between that and the seafoam my front cat has finally quit working properly.
my question is, can i get away with replacing the first cat with a high flow cat from magna flow and remove the second cat downstream with out setting off anymore check engine lights? i was just quoted 350 + labor to get the new cat assembly, and would like to spend alot less.
thanks yotatech
thanks yotatech
Yes that is what I did. I live in NJ and passed with flying colors. You will need a high flow cat , then a test pipe with an 02 sensor in it and the some kind of muffler. I would look into that price of $350.00. A new cat is $100.00 plus a new muffler , and a test pipe. If you can weld your in good shape and can get er done cheaper. I could not weld and had it done for $260.00.
thanks yotatech
thanks yotatech
most fixes involve using some sort of o2 simulator. I personally think the simulator is a band-aid, but at this point, I am unwilling to dole out the $2k+ for a factory dual cat assembly.
If you do end up finding a replacement cat that doesnt throw a code, please let all of us know, I know I need one.
so is the consensus so far that i need to shell out the 350+ labor or can i just get away with a high flow cat and a new location for the downstream o2 sensor?
I was told that these guys, http://www.empirepao.com/ make an O2 simulator, as well as urd has one too. if you decide to do the single cat, this should mask the cel.
Like I said I have a single high flow cat from Lc engineering. I have a California model 2.7l. I removed the stock setup and installed a Lc header, high flow cat, test pipe with 02 sensor and new muffler for about a year. No issues and I passed inspection. Maybe I'm lucky but the 02 sensors read before and after the cat, why would 2 small cats be more efficient to one bigger hi flow cat. Just my 2 cents. You can buy the simulator after you get the code if you need it.
Is your one cat bigger than the factory cats? All cats are high flow now, or so I'm told.
The stock cat on a cali model up front is about 8inch wide a 10 inch long. It then travels about 24inches to a second smaller cat. I replaced with 2.5 inch lc cat in and out. No problems at all. The six cyl engine needs more of a cat I would say so It may not work. But I would try it and then add the Simulator later if it does not work.
alright, so would the better choice then be to just shell out the $$ for a new part (350$) or go to a new cheaper muffler and just get an O2 simulator from URD? i want my truck to run perfectly and im not sure how much i trust an O2 simulator
BTW what does the muffler have to do with any of this discussion?
If that is so, why didn't they make them standard on all models. It's probably mandatory in California to have 2 cats after a certain year. I think its overkill. If mine works without a code ,and its a little larger than the second cat ,who's to say its not as effecient as 2 smaller cats.
The O2 simulator doesn't effect how the engine runs because its for the rear O2 sensor, the real question is will you pass smog with it? (It is illegal for road use) In your state do they test the tail pipe emissions or just look for a CEL being thrown by the ECU?
i have no clue abt the muffler part of this discussion, and can we please not turn this thread into an argument over stupid stuff? i need to get a concrete answer on what is the cheapest way and also what is the best way to fix this without getting a recurring p0420 code
thanks guys
the only thing that really bothers me about the o2 simulator, is if the rear o2 sensor actually has anything to do with how the ecu tunes the motor, or if it is there soley to check the effeciency of the cats.
if all the rear o2 does is check the cat(s), then I would have no worries using the simulator in conjunction with a regular high flow cat.
can anyone confirm or deny that the rear o2 is there for anything but checking the cat(s)?? or does it have anything to do with how the ecu tunes the engine??
i'd think the front o2 does all the tuning, but i've been wrong before.
florida doesnt smog test the vehicles, dont ask why, they just dont, so that part doesnt matter for me. what will be different about my tail pipe emissions if i use an O2 simulator?
thanks guys
thanks guys
So is your problem now that you're getting a P0420? If so, as long as your cats aren't clogged and you aren't worried about the smog police and you can handle some soldering and wiring, I'd just install the sim and leave the cats alone:
http://www.urdusa.com/product_info.p..._id=1230100014
The simulator will just fake the ECU into thinking the cats are working fine, it will not change emissions or anything else.
ok... so how would i tell if my cat is clogged?
and would i gain anything by replacing both cats with high flow? or removing one cat and replacing the other with a high flow?
"Off the truck" as long as there isn't a curved section of pipe, you can tell just looking to see how much light you can see through the honey comb.
Again, as I understand it, ALL cats now days are high flow, so you already have high flow cats and putting on another high flow cat will only help emissions if your old cat is bad.
okay, so one more question. i dont believe that i have any o2 sensors after the second cat, so could i not just cut that one off completely and get a new cat just to be safe for the front one and run the o2 simultaor?
What codes are being thrown now? If you don't have a rear O2 sensor in place you should be getting more than just a P0420. A working rear O2 sensor has to be in place for the URD sim to work.
