Replacement DE Fogs for 98-02 runners
Old 03-07-2005, 05:17 PM
jimbob's Avatar
Looking for any info as to where to get a replacement fog for my 02 - it was broken when i bought it (as were most that i looked at). Dealers want $368 for factory replacements --- NO FREAKIN WAY!!!!
I ran across these :
http://www.rallylights.com/hella/Mic...p#Micro_DE_HID
~$50 is a hellava lot better than $368!!!!
I'm wondering if part # HL74528 is a direct replacement for factory lamps .... and if so, will it mount into the factory mounting bracket ---- or do i have to get the optional bracket to mount it? The kit (part # HL74560) looks like a good possibility, but i'm hoping all the extra brackets aren't required --- and i only need one.
Anyone know where to get a reasonably priced replacement or if this part # (HL74528) will bolt right in?
Two years with a broken DE is really starting to grind on me. :cry:
Old 03-08-2005, 03:37 AM
aowRS's Avatar
The HID Micro DE lights are $693 per set. Not sure where you saw $50?
The other DE lights (halogen) listed on that site should fit as direct replacements ($154). Do not buy them from the dealer!
Susquehanna Motorsports is a great outfit. I purchased my Hella 4000 lamps from them three years ago with no problems whatsoever. I would recommend calling them directly, as the info listed there can be somewhat confusing.
Andreas
Old 03-08-2005, 07:21 AM
jimbob's Avatar
If you look about half way down the page, you can get an individual lamp for $49.25.
This is the unit I have questions about - will it bolt right into the factory mounting/aiming bracket to replace a lamp with broken glass?
voiddweller
19
05-02-2016 09:10 PM
TheManOutside
06-18-2015 03:32 PM
infinityisfive
06-16-2015 06:51 PM
Juan Manzione
06-10-2002 04:12 AM
MRael
15
06-05-2002 02:20 PM
Quick Reply: Replacement DE Fogs for 98-02 runners
