Replaceing ECU
Replaceing ECU
Hello everyone,
So the ECU in my 2001 4runner got fried and I need to replace it. Where exactly is it located and does anyone have any tips that I should know about?
Thanks in advance,
Ben
Thanks in advance,
Ben
Thanks MTL. I took it to the stealership yesterday and they said it's dead. I think my friend crossed the jumper cables when she was giving me a jump the other day which subsequently fried the Alternator Fuse and ECU.
From what I've read the ECU will calibrate itself right?
Actually on an 01 it's above the glove box. Remove the glove box, the heater duct and the metal brace below the air bag and you'll see it. I don't know if it'll come out with the airbag in the way though. If you're replacing it yourself disconnect the battery first.
Here's a pic......
The dealer also stated that the ETCS may be bad too. Is it possible that the ETCS is sending an error code only because the ECU is bad or will I for sure have to replace both?
I think the dealer is playing parts replacement because they have tried everything in the FSM diagnostic tree and narrowed it down to that (at least I hope thay have). There's not much anyone on here could say beyond that without know alot more detail about your situation (ie symptoms) and what the dealer has tested so far.
*Note to self* Keep overly helpful girls away from my rig.. =/
I'm curious where you're getting your replacement. I went to the stealership when I figured I had a bad one...they wanted $1100! I ended up getting one online for $300, flashed with the newest firmware available. Works great now. FYI the cpu can be bad and still run, I ran on 5 cylinders until I could get my new one swapped in.
Yeah bro, ECU's have to be the bane of all things to go wrong...I think I just lucked out that it would run hehe...as per what the dealer said as well. I cringed when I hooked up my scantool and had *tons* of CELs, even though the dummy light never lit up...go figure.
It's either that or a burnt/damaged ground somewhere (since low ECU voltage will cause similar problems).
Did you get a chance to replace it yet?
If not, might wanna make sure that the ECUs match...an auto trans ECU won't work right with a manual, and if you have a later model 3rd gen with the security "chip" inside your keys you will have to go to the dealer to reprogram it...it won't run until you get that done. Atleast that's what I've been told...
Well, I swapped out the old ECU with the new one this morning but it's still doing the same thing. I don't have the security chip on my ECU so it shouldn't have to be reprogrammed. Looks like I'm going to have to take it back to the dealership and have them fix it.
