Replaced fuel injectors, now throwing multiple CELs...
Old 08-04-2011, 08:22 PM
UNR.Grad's Avatar
My '97 was throwing a P0305 code and replacing the plugs/wires did nothing to clear the codes, neither did swapping coilpacks. I tested the fuel injectors and #5 was bad, it had a really high ohm reading.
I replaced all 6 injectors and re-assemble the car. It stumbled pretty bad at the start and threw a P0303 code, I reset it and it started to get better. I thought it was just the vasoline (I used probably too much) burning off that I used to lube the o-rings , as other members have commented on this.
After a few more miles of driving it threw a P0125 code. I reset it again and now it accelerates fine and runs at high RPMS ok but still stumbles badly at idle. Now it's throwing a tons of codes: P0171, P0300, P0301, P0302, P0303, P0304, P0305, P0306.
I'm not sure what to do now, any ideas. It seems like it points to a fuel leak but I don't smell any obvious gas scents in the engine bay.
Any help would be appreciated...
Old 08-04-2011, 09:54 PM
UNR.Grad's Avatar
I've done some searching, maybe I have a vacuum leak now? Any other ideas?
Old 08-05-2011, 07:58 AM
Bobs4Runner's Avatar
Make sure there all seated correctly, all the wiring is attached. You don't need a lot of vaseline on the rubber gromets, that could be the issue. Make sure everything is tightened and in its correct spot. I know the gas rails can be tricky to take off and put back correctly.
I've had to replace 1 injector and had to do it twice due to it being seated incorrectly..gas all over.
Bob
Old 08-05-2011, 06:32 PM
UNR.Grad's Avatar
Bob
I don't have any leaking gas into the engine bay, but I think I will do it over again and see if that helps.
The gaskets on the plenum do not need to be changed right? Maybe there is a leak there.
Old 08-05-2011, 06:36 PM
rworegon's Avatar
The gaskets on the plenum are listed as non-reusable per the FSM as is the the metal gasket between the throttle body and the plenum.
Old 08-05-2011, 07:12 PM
Due to my mileage and being the third owner, I replaced all the gaskets, rubber grommets and whatnot. I had to do it twice also, so don't feel bad. Just make sure you have no leftover bolts or screws.
Old 08-05-2011, 07:50 PM
UNR.Grad's Avatar
Do you have the part number for the gaskets?
Old 08-06-2011, 08:27 AM
UNR.Grad's Avatar
This morning I started the process over to replace the fuel injectors and when I got to the upper plenum the bolts/nuts securing it were loose. In the rush to put it back together the first time I had only finger tightened them and forgot to torque them down, causing a massive air leak. I torqued them down, put the rest back together and fired it up. It's running great now.
Lesson learned: don't be a dummy and take your time putting everything back together!
Old 08-06-2011, 08:38 AM
rworegon's Avatar
It's nice to find the cause before you had to dig all the way back into it. Your vacuum leak idea back in post 2 panned out bigtime.
Many of us have made a mistake like that....it just seems to be part of wrenching.
steve miller
10-10-2015 01:40 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Gamble_STi
07-07-2015 07:54 PM
skoti89
07-06-2015 07:45 PM
karbin
07-05-2015 11:37 PM
Quick Reply: Replaced fuel injectors, now throwing multiple CELs...
