Removing tow hooks - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-10-2007, 12:40 AM   #1 (permalink)
Removing tow hooks
So im having a hell of a time getting one bolt out on the tow hook. Im trying to remove it to get a new set of tow hooks and install a light bar and i think i stripped it because its just spinning in place. But i dont know what i stripped, the bolt or the nut inside the frame that it screws into. That little bastard just does not want to come out. The other ones came out just fine, but this one will not come out. Right now im in the long and slow process of drilling through the head of the bolt so that i can at least take the head off and be able to install my light bar. but i would like to be able to take it all the way out if possible. Does anybody have any techniques or advice they could give me?
Thanks
__________________
2002 Taco ExCab- 5spd, 4wd, 3.4L
Mods:
Deckplate mod, ISR mod, more to come...
Cobra_R is offline
Old 03-10-2007, 02:09 AM   #2 (permalink)
if you get it out can i buy your tow hook from you?
jakesooy is offline
Old 03-10-2007, 02:20 AM   #3 (permalink)
lol sure...ill pm you if i can get it out.
__________________
Mods:
Cobra_R is offline
Old 03-10-2007, 04:55 AM   #4 (permalink)
Gt4r97's Avatar
I had the same experience. There's one bolt up there that i didn't able to take take out. Eventually, I gave up my plan to replace mine!
__________________
Gt4r97 is offline
Old 03-10-2007, 05:52 AM   #5 (permalink)
usmarinerecon's Avatar
Drill it out and buy a tap and die set. They're not too expensive. If you're going to do it, you might as well do it right. esp. if you're going to put new hooks on you are going to need all the support form both bolts when getting yourself or a friend out of a hole.... nothing like a hook thru the windshild or radiator.
usmarinerecon is offline
Old 03-10-2007, 07:48 AM   #6 (permalink)
98LimitedCustomized's Avatar
another idea would be to cut the bolt off with a sawzall or cutting grinder and going from there. Might be easier than drilling it out like crazy.
__________________
98 Limited, 3.4 Auto, 4.30's w/E-locker; TJM T-15, Tundra coils/OME lift, 235/85/16 Nokian Hakka 10's, custom 200 amp GM alternator, dual batteries, Brembo/PF brakes, modified Injen intake, Hella 500's, Hayden 678, Taurus Fan, etc
98LimitedCustomized is offline
Old 03-10-2007, 08:16 AM   #7 (permalink)
4Crawler's Avatar
Likely the nut that was welded up inside the frame that the bolt threaded into has broken loose and that is what is spinning. Aside from cutting the bolt off with a saw or cutoff wheel, another option is to find (or make) and access hole near the nut then weld it back in place.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 03-10-2007, 08:57 AM   #8 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
Quote:
I was thinking the same thing.....since it is a blind hole, it will be nearly impossible to repair without cutting a fairly large access hole and welding the nut back in place.
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Old 03-10-2007, 09:18 AM   #9 (permalink)
Staff
UKMyers's Avatar
Send a message via AIM to UKMyers
SAWZALL BABY!!
__________________
2006 Tundra Double Cab TRD Offroad 4.7 IForce Bilstein 5100's, 285 BFG's, Panther Wheels, Limo Tint
1994 4-Runner SR5 5 Speed SASed, Detroits, Armored, Dual Cases, 37" MTR's Build up http://www.yotatech.com/showthread.php?t=104000
Need Toyota Parts? www.davezoffroadperformance.com
Quote:
...why does my IFS have no flex, and what can I do to make it flex???
UKMyers is online now
Old 03-10-2007, 08:59 PM   #10 (permalink)
haha yea ive thought about the sawzall, i dont have one so id have to borrow one but im already more then half way done with the drilling the bolt idea so ill probably just finish that off and buy a tap and die set. i didnt even think about drilling a hole into the frame and welding the nut back in place however, i may try that out.
__________________
Mods:
Cobra_R is offline
Old 03-10-2007, 09:17 PM   #11 (permalink)
Brendan's Avatar
Send a message via MSN to Brendan
i had the same problem. the weld broke on the nut inside the frame. i was able to get the bolt out by using a pickle fork to pry down on the bolt head creating enough friction between the nut and frame to prevent it from turning.
__________________
1992 "Truck"
1978 Land Cruiser FJ40
pig and elephant DNA just won't splice :(
***DO NOT CLICK HERE***
Brendan is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Tow Hooks CTB 95.5-2004 Tacomas & 96-2002 4Runners 11 05-01-2008 03:29 PM
tow hooks?? daniel_loz 86-95 Trucks & 4Runners 15 01-10-2006 10:08 AM
Front Tow Hooks 4x4Fink 95.5-2004 Tacomas & 96-2002 4Runners 24 12-13-2003 05:32 PM
Tow hooks on a 3rd gen 00Runner 95.5-2004 Tacomas & 96-2002 4Runners 14 07-24-2003 03:08 PM
looking for tow hooks rockfordrunner 95.5-2004 Tacomas & 96-2002 4Runners 4 05-24-2003 06:11 AM
2009 InternetBrands, Inc.
