Removing Limited Fender Flares ALL
Removing Limited Fender Flares REAR
Sup guys I am going to swap fender flares with my new rig but I can't figure out how to remove the REAR flare conncected to the rear quater panel. how do I get acess to the bolts holding it on? I took out the rear interior panels but there is nothing there conected to the flare. any info will be great thanks.
carefully, hah. Those things get brittle after a little while and they just end up snapping off. When you go to the Stealership to replace the broken clips, take you VIN number with you, it will be easier to find the parts. Recently I replaced some clips on the front fender flares, the large ones at the base of the front fender. Those buggers are $13 bucks a pop. the smaller ones are like $2 bucks a pop. So, if you don't have to take them off, don't do it. They are an item that will need to be replaced if you pull them off.
Good luck
Good luck
06-01-2021 01:51 PM
FS[PacNorWest]: Parting 2000 4Runner Limited 4WD Marysville, WA
DeathCougar
04-01-2018 11:29 PM
justdifferentials
Just Differentials
14
09-24-2017 08:32 PM
09-04-2015 09:27 AM
