YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-25-2003, 01:01 PM   #1 (permalink)
Removing the inside panel on Rear Gate of 4 runner
The lock has shifted on my rear gate on my 97 4 runner and I wonder if anyone knows how to access it so I can reset it back in the slot...sounds confusing ,eh? the slot I insert my key into has come loose from the body of the rear gate and I need to get to it to re-attach the lock in it's position...how do I get into the panel space to access the lock mechanism to repair it? it is located on panel above the rear license plate..............
__________________
"Only a biker understands why a dog hangs his head out of a car window"
MrBob is offline
Sponsored Links
To remove this ad, register today!
Old 07-25-2003, 03:21 PM   #2 (permalink)
MrBob,
Ask Jacksonpt. He recently did some repair work on his rear tailgate about 2 montsh ago.
Bob
Bob_98SR5 is offline
Old 07-26-2003, 12:04 AM   #3 (permalink)
butnut's Avatar
A small PITA. It's all done from inside. Pry off the tiny panel cover from the pull down strap. Unscrew the handle. Pry the plastic panel (inside) off the tailgate. Lift up to release the rubber top trim. Shimmy it out easy. Now, you'll see a big metal panel...all those screws come out. You can access the garnish and guts from there. There will be a few wires/connectors stuck on the metal panel. I just hung the panel off the tailgate with a long bungee. Good luck.
__________________
Brian
B like dat den...
2006 DuB CaB Tacoma
Speedway Blue TRD Sport
butnut is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Removing Panel Under Steering Wheel Midnight Skys 86-95 Trucks & 4Runners 4 09-04-2006 08:40 PM
What Spring Compressor would you get for removing rear coils? ('99 Runner) yoda-g2 95.5-2004 Tacomas & 96-2002 4Runners 5 05-26-2005 01:24 PM
Help - Removing Panel from Rear Window? Matt in AR 95.5-2004 Tacomas & 96-2002 4Runners 0 05-16-2005 07:08 AM
Need help removing the door trim panel. jahMcS 95.5-2004 Tacomas & 96-2002 4Runners 4 12-15-2004 08:23 PM
Removing Inside Panel of 3rd Gen. Liftgate. Beachrunner 95.5-2004 Tacomas & 96-2002 4Runners 14 02-09-2004 11:25 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
