Removing front seat in 1995 PU
Sorry for the dumb question. (I did try some searches...) Is removing the front bucket seat from a 1995 PU as direct as removing the two front 14mm bolts? Or are there four bolts (two more in rear)? Also, any electronic sensors, ie for seat belts, that must be disengaged prior to removal? Thanks
There are two bolts in back as well, but the sensor for the seatbelt connects through the seatbelt buckle on the floor so you're all clear there. You can have them out in about five minutes...
09-04-2015 09:27 AM
icentropy
07-09-2015 02:12 PM
