| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Removing Exhaust Manifold for LC Engineering Header
__________________
185K Miles and Rising My 4runner 1996 Toyota 4runner Base 2.7 4cyl 4x4 Desert Dune w/Deckplate Mod, BFG KOs,Alpine CDA-7894, Rockford Fosgate Power 500a2 powering an Alpine Type R 15' sub, Rockford Fosgate 200a2 powering 5 1/4 Alpine type R rears, Kenwood KAC-7201 150w x 2 powering front polks,Cosmo Fuel Pressure Regulator, Magnaflow Exhaust,99+ headlights,Hoodscoop, Soon to be turbo(have the manifold, someone sell me a turbo damn it!) |
#2 (permalink) |
Did you get new studs and nuts with the header? IF so then use a nut splitter, and they should come off pretty easy, as long as you have enough room to swing the hammer.
__________________
Brandi You heard of the boy named Sue, Well I'm a man named Brandi! '85 extra cab pick-up, Up on blocks waiting for time and money. '85 4-runner with 3" lift, 33's, 4.88's, rear ARB (still trying to get air to it), Downey intake with K&N filter, some type of header, Camo Int. |
#3 (permalink) |
WD40 is not a very good rust penetrator. Try picking up some PB Blaster, Kroil, or the like. Even then, it helps to spray the nuts & studs every day for about a week before you try removing them. Just hitting it with the lube right when you need it doesn't allow time for it to penetrate and do its thing.
__________________
1985 4Runner 22RE 5spd, mostly stock |
#4 (permalink) |
Yea i've been spraying wd40 on there for the past few days, but your right its definitely not good for removing rust. I'll pick up some penetrating oil today at Autozone and see if it makes a difference.
__________________
#5 (permalink) | |
Quote:
__________________
99 taco, LCE header, fipk, el cheapo baja driving lights, 2" body lift installed, OME leafs, tundra springs&shocks, pics coming soon! audio: alpine head unit, audio control 4.1 parametric eq, lightning audio coax speakers in rear, arc audio components up front, rf punch 360.6 amp, 2 8" kicker solobarics, lightning audio 400.2, 1/2 farad cap. adrenaline: '03 zx6R 636, full leathers, several sets of worn out knee pucks. |
#6 (permalink) |
I used to take an oxy/acetylene torch to them for a minute then they would usually spin right off.
#7 (permalink) |
OMG!!! I didn't think that I would EVER find a 3RZ-FE that looked dirtier/rustier/fithier than mine..
I NOW have! Okay, back to the topic at hand. I tried to remove the manifold nuts (or whatever you call them) on my truck, and one came off fine. The next one I tried, both the stud and nut started coming off together, and I must have totally freaked, 'cause I immediately started tightening it.. ![]() Now that I know that they come off together (without breaking), I'm going to re-try and take off my manifold (which is cracked 'n rusty after only 66K miles).. This time I'm going to break out the PB blaster and let them soak for a few days (instead of hours or minutes), I guess.. Good luck getting your manifold off. Obtw, why don't you unbolt your air resonator bracket? I've taken mine off several times--just for kicks and giggles--and it comes off everytime. Plus you'll get a tad bit more room to work with..
#8 (permalink) |
Yea good idea, I thought it was bolted into the head though?
Any yea my engine is crazy dirty. I took it mudding this summer and i'm still finding mud in random places. Plus with the tons and tons of salt that they dump during the winter rust on all the cars is a given. I bought some PB Blaster today and i'll give it a try. I'm gonna take your advice kwak and buy a breaker bar seeing its only around 10$. But i must say, Toyota really seemed to have dropped the ball on the 3rz manifold construction. You can see the crack in it right below the pink circle in my picture
__________________
#9 (permalink) |
its about time! I dont see the magnflow hi flow cat on there!! :ROLL:
__________________
02 4runner conversion complete! |
#10 (permalink) |
Yeah, it is secured to the head via two 12mm bolts..
![]() You don't have to take it off, it will just give you a little more room if you do. |
#11 (permalink) |
lol it's bolting right up to the header once I get it on there
![]() Yea, Schuey I just went outside and took it off didn't help but you were right.I left that PB buster on there for about 3 hours but its still not budging. I'll just keep doing it all week long I guess
__________________
185K Miles and Rising My 4runner 1996 Toyota 4runner Base 2.7 4cyl 4x4 Desert Dune w/Deckplate Mod, BFG KOs,Alpine CDA-7894, Rockford Fosgate Power 500a2 powering an Alpine Type R 15' sub, Rockford Fosgate 200a2 powering 5 1/4 Alpine type R rears, Kenwood KAC-7201 150w x 2 powering front polks,Cosmo Fuel Pressure Regulator, Magnaflow Exhaust,99+ headlights,Hoodscoop, Soon to be turbo(have the manifold, someone sell me a turbo damn it!) Last edited by SpecializedBrder; 11-29-2004 at 07:07 PM. |
#12 (permalink) |
i think a swivel socket with a long extension will do good on that. my experience with exhaust studs is that if the nut is on there good, it'll just take the stud right out of the head as steel won't rust to aluminum.
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts past toys: 1984 4x2 1979 4x4 1991 4x4 |
#13 (permalink) |
why not use an E10 (?) torx socket and just take all the bolts out of the head, then replace each of the bolts and nuts altogether going back on.
thanks for the fore-warning tho. i should be getting my LCE headers tomorrow. i guess i should save myself some time and get the torx socket and studs first.
__________________
Yotas I've known... 83 pickup 87 Extracab SR5 4WD pickup 92 4WD pickup 85 long-bed pickup 90 pickup Yotas I own... 00 Extracab SR5 TRD Tacoma (3RZ) **FOR SALE** 85 SR5 4Runner Check the LongBeachRacers, pounding Tacos in the desert! |
#14 (permalink) |
i got a e10 torx socket. hit me up if you neeed it.
__________________
#15 (permalink) |
Well that was a pain. I used the e10 torx socket and broke off the ends of both studs and then used a breaker bar to get the nuts off. One nut and stud came out together and the other stud I used a pair of pliers on. Now comes the big question...how the hell do i get the headers in? the transmission dipstick is in the way and the headers go in at a really weird angle. I'll try to take some pics soon
__________________
#16 (permalink) |
Well, I finally got the header on and put on the high flow cat. The 2.7 sounds really great w/ the magnaflow exhaust and header combo. It drives 100% better than when I first got it. With the new exhaust system, polyurethane bushings, and rear addco sway bar, it actually gives this 4banger 4runner some balls. Next up on the List is the AEM short ram intake. My Turbo manifold is up for sale in the classifieds if anyone wants it. Decided not to go that route
__________________
#17 (permalink) |
I've ran the lc 2.7 header for 2 years or so and love it. On the rust note though find a boating store near you and get something called penetrol has a nice orange scent to it. I use it in the marine business for salt water rust and corrosion and it makes pb blaster look like cheez whiz. Blaster is good stuff still though
__________________
My truck gets 1 new dent and pops 2 old ones out 98 Tacoma SAS'ed marlined geared locked etc etc 04 Rubicon wrecked soon to be new playtoy 05 Titan current concrete commando |
#18 (permalink) |
Yea, im impressed with it so far. It definietly picks up a lot faster. That PB Blaster stuff STINKS. It kinda smells like old lady amplified. But whatever as long as it works right?
__________________
| Tags |
| 27, 3rz, 4runner, autozone, bolts, buster, engineering, exhaust, header, lc, manifold, penetrator, remove, rusty, thread, toyota, turbo |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| LC Engineering Exhaust | MAXIMUS1968 | 86-95 Trucks & 4Runners | 16 | 10-28-2006 02:43 AM |
| 22R/RE LC Engineering Pro Flow Cat Back Exhaust...BARELY USED | brendonv | The Classifieds GraveYard | 8 | 07-03-2006 06:53 AM |
| LC Engineering Header? | 90FFyota | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 11-22-2005 04:39 PM |
| lc engineering header? | wifesaysimadumbass | 95.5-2004 Tacomas & 96-2002 4Runners | 20 | 08-21-2004 12:28 AM |
| Pics of LC Engineering Header installed | Big Nasty | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 04-05-2003 05:34 PM |
