Removing the charcoal canister?
Old 07-26-2005, 12:51 PM
dwh91102's Avatar
Sorry to make a new thread, but I'm curious if anyone has done this and what the consequences of this will be. If you ask why check out my other thread
https://www.yotatech.com/forums/f2/1989-fuel-pump-bracket-63855/
Old 07-26-2005, 01:48 PM
rimpainter.com's Avatar
My understanding is that fuel vapor will be exhausting into the air verses contained and back into the engine. Never a good thing to have fuel vapors lingering around!
Old 07-26-2005, 01:52 PM
geneius's Avatar
Yup, I agree what <96 Runner> said.
In fact, I just installed a charcoal canister on my toilet so my family would stop complaining.
Old 07-26-2005, 04:25 PM
Guest
94x4's Avatar
You could fabricate a fitting(s) that would accomodate the hoses that run to and from the canister and thereby eliminate the canister altogether without worries about potential fuel vapors..., FWIW.
Old 07-26-2005, 04:26 PM
Guest
94x4's Avatar
Man, everyone needs one of them.
Old 07-26-2005, 04:44 PM
dragon564's Avatar
The canister is required for emmisions. That said I am not the LAW or the authority emmisions. The fuel tank must be vented to allow for expansion and contraction of the fuel in the tank, it also provide some help when filling up. As for "Ting" the lines together, the return line on a fuel injected enginge is under pressure, put the CC vent line on that could pump gas out of the CC. From the pic that you have on the linked post I would say what you have there is the Assy from a Carbed truck which does not have the return line. You can always drill the replacment and fab the return line fitting using some brake line tubing from just about any donor car, or hit a pick and pull wrecking yard to get your hands on the exact match for your truck.
choppe777
05-16-2016 08:00 AM
Linked2002
3.4 Swaps
7
12-15-2015 01:31 PM
old87yota
09-09-2015 12:39 PM
gp66
09-07-2015 08:29 AM
94whiterunner
07-12-2015 07:15 PM
Quick Reply: Removing the charcoal canister?
