Removed front seat, trouble getting it in
i removed my seat and when i tried to put it in the tacks holding the nut broke, it happened on both front bolts. i cant see a way to get in there to re-tack it... on one of the sides i pulled it until the metal of the body opened up and now i can't get either side bolted in. is there a fix to this? any ideas so i can actually ride around with a passenger?
might need to cut out that section and weld in new plate with bolts welded on the back side, other then that use a big washer to keep the bolt from pulling threw when u tighten it down.
If you're saying what I think you're saying it's a pretty common problem. I fixed mine by drilling a hole through the floor and using a long bolt. Others have done different fixes.
Maybe this thread will help?
http://www.toyota-4runner.org/3rd-ge...ount-fail.html
Yep this is it
i couldn't find anything in the search. thanks for this.
09-04-2015 09:27 AM
icentropy
07-09-2015 02:12 PM
