| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Remote Starter...Ignition Override
__________________
2000 4runner Limited 4wd, TJM-15 w/IPF driving lights and a Warn m8000, Stubbs Sliders, Surco safari rack, 883s up front, 890s in the rear, OME firm shocks, 2" RB body lift, Custom Hitch, 285/75 Baja MTZs on 16x8 American Racing Teflon Chambers, K&N FIPK, remote start, Pioneer 8600, 2 JL Audio 12s |
#2 (permalink) | |
Quote:
If so you may need to override that to allow it to start.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#3 (permalink) | |
Quote:
__________________
96 4Runner SR5 SC | 3" Revtek Front/OME 891 Rear,Diff/Panhard Drop|AirLift bags|285/75/R16 Nitto Terra Grappler|Eaqle 121 w/TRD Logo|Bilsteins|Cross-Drilled PS w/PF Pads|Silver Reverse Gauges|Custom Grill|Catch-All Floor Mats|Sylvania SilverStar|Weather Tech Visors|Clear Corner/Fronts|Alpine MP3/WMA/CD|99+Headlight/Console Mod|K&N FIPK W/Drycharger|Optima Redtop|Trans-Cooler|Remote Start|PICS|PICS2| |
#4 (permalink) |
After reading a few websites a little more closely, I figured out you have to buy a bypass module to make the computer think that the key is in the ignition. Picked it up at the local audio shop for $30, put it in, and now everything is working fine.
Install was a little trick thanks to the crappy directions, but remote start for $75 total isn't too bad!!
__________________
#5 (permalink) |
I tried researching this mod a while back but nothing came out of it. The only thing holding me back is wether or not that bypass module (which is necessary i beleive) makes my car less secure because it makes the chip in the key useless. Any links to the kit you bought?
__________________
1999 Imperial Jade Mica Toyota 4runner Limited 4wd -Jensen Flip Down Monitor -Blaupunkt DVD/VCD/CD/Mp3 -Bed-Liner coated skidplates |
#6 (permalink) | |
Quote:
The convienence of an alarm with remote start more than makes up for it in my book.
__________________
#7 (permalink) |
i guess the newer keys have the transponders built in, so u need a bypass module. i had one installed in my 98, didnt need the bypass module. no bypass module means 1 extra key.
__________________
07 4runner 4.7 SR5 98 4runner 3.4 SR5 87 FJ60 |
#8 (permalink) |
I'm about to do the same instal in my '00 Runner. The remote starter is made by Bulldog Security and I am just waiting to get a "T Harness" to simplify the install (less cutting and splicing of the factory wiring harness). I understand that I will need a bypass module as well. Bulldog apparently has two types of bypass modules - one where you insert a key and the other has the ability to "learn" the bypass codes / signals.
Was it a real PITA to install? |
#9 (permalink) |
My remote starter is made by Bulldog Security also. I didn't get the "T harness", prob would have saved some time but I figured I didn't really need it. The install wasn't too bad, just took me a little while to find a few of the wires b/c this was my first time installing something like this. I got a universal bypass module from the local audio store, so I did lose a key but I had three to begin with so I didn't care. The bypass module was pretty easy to install, prob only took me 15 min.
Overall, the install isn't too bad and well worth the $$ you save by doing it yourself.
__________________
#10 (permalink) |
Unless I'm reading something wrong, I don't think that the bypass module makes the transponder useless. The only time that the bypass module disables it is when the power is sent to the remote starter (and also to the bypass module) and is started. I am pretty sure that the transponder is still effective the rest of the time.
__________________
#11 (permalink) | |
Quote:
__________________
#12 (permalink) |
From what i read this is what i understand (correct me if im wrong) Im not exactly sure which method keeps the transponder security feature enabled? But It seems like a bypass module is necessary,(two versions) one with a spare key in it, one without.
Is there a remote starter kit, if so, where is a reliable place i can purchase one? And are there any downsides to having a rem. starter? Sorry for all the questions, just trying to get as much info as i can. Thanks
__________________
1999 Imperial Jade Mica Toyota 4runner Limited 4wd -Jensen Flip Down Monitor -Blaupunkt DVD/VCD/CD/Mp3 -Bed-Liner coated skidplates Last edited by FlzRider; 01-05-2005 at 04:22 PM. |
#13 (permalink) | |
Sponsoring Member
Quote:
http://www.commandocaralarms.com/ I have the the two-way FM-870 and love it. The install was "interesting" the first time through, it took me about 4-5 hours. If I were to do it again, it'd be about 2 hours. I've also installed their RS-560 which is a one-way unit and it's been awesome. fwiw, working through the options on the site says that a 1999 4Runner will require a bypass module. They have two options - one is transponder based for $20, and a more generic one which is $35. The transponder based one will maintain the security of the embedded chip in the key since it'll be tagged to your transponder.
__________________
~ Mark '96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams |
#14 (permalink) |
The FM-870 is a little more than what im looking for. I just want a remote starter that is fairly simple to use, reliable, and wont take away any security features my car already has. Anyone know something that will fit this bill?
__________________
#15 (permalink) | |
Sponsoring Member
Quote:
http://www.commandocaralarms.com/ite...ProductID=1186 Or, the EZ-2500 for $65: http://www.commandocaralarms.com/ite...?ProductID=495 Stay FAR away from Ultra Start. I bought one and sent it back the next day. It was JUNK.
__________________
#16 (permalink) |
The EZ-2500 looks pretty good. Do i still need to buy a bypass module, if so, which is the best for my application (i want to keep all my existant safety features)? Anything else necessary or that will make it easier to install? Thanks alot for the help
__________________
#17 (permalink) | |
Sponsoring Member
Quote:
![]() As for "which one", I'm really not comfortable deciding for you since I don't have any first-hand experience. Drop a line or a call to "Ryan" (ryan@slickcar.com) from Commando, he's always been quite helpful to me. Tell me "Mark from Seattle" says "hi"!
__________________
#18 (permalink) | |
Quote:
just think about it, sucks to use one remote to start it and another to unlock the doors, I recently installed my system and removed my old factory one. I prefer one remote any one system
__________________
#19 (permalink) | |
Sponsoring Member
Quote:
__________________
#20 (permalink) |
I actually dont mind having two remotes. I have barely anything on my keychain.
I looked at a couple places online and am having trouble finding a toyota transponder bypass module. The ones at commando car alarms dont say if they are the kind that require a key or not?
__________________
#21 (permalink) |
The only reason the bypass module would need a key is if you have a transponder (sp) chip in your ignition key.
__________________
1990 4Runner SR5 3.Slow, Automatic, Air Intake Mod, Magnaflow muff 31's, Pro Comp ES9000 Autocommand Remote Start Removed = Running boards, lower rear quarter, rear bumper |
#22 (permalink) |
1999 and on have the transponder in the key.
__________________
#23 (permalink) | |
Sponsoring Member
Quote:
__________________
#24 (permalink) |
You don't have to get a Toyota transponder....I picked up a universal one for $30 at the local audio shop and it works fine (it did require a key).
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Remote Starter | HogMan | FJ Cruiser | 2 | 02-11-2007 08:13 AM |
| Remote Starter Installation Help | lr9788 | Vehicle Audio & Home Entertainment | 4 | 01-05-2006 05:12 AM |
| Remote Starter | Tacojuice | 03+ 4Runner/GX470, & 05+ Tacomas | 6 | 12-28-2005 06:34 AM |
| I Need Diagnosis Help: Ignition? Starter? | hhinojosa | Maintenance & Repair Archives | 4 | 11-22-2004 03:24 PM |
| Remote Starter | 2002 SportEdition | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 11-04-2003 07:38 AM |
