Remote Mount Turbos - YotaTech Forums
Go Back   >
Remote Mount Turbos
LinkBack Thread Tools Search this Thread
Old 09-05-2004, 10:55 PM   #1
zach34's Avatar
Remote Mount Turbos
I picked up an issue of Turbo and High Tech Performance for some reading material on the 7 hour drive to Arkansas. There was an article on remote mount turbos. Basically it's a turbo mounted where your muffler would be. Turbo lag isn't an issue, because of the speed of the exhaust gas and the large amount of straight pipe used.
I'm a little lazy so I'm not going to go over the whole article, but they dyno'd a stock '96 and up V6 Tacoma at 140 rwhp. After the turbo, ~220 rwhp. Pretty impressive. Anybody heard of this?
zach34 is offline   Reply With Quote
Old 09-06-2004, 12:45 AM   #2
Flamedx4's Avatar
Doesn't make any sense. Love to see the details, but traditionally turbo lag is reduced by the shortest possible pipes, both exhaust and boost side. Mounting the turbo that far away sounds like a recipe for turbo lag measured with a calendar... We played with turbos many years ago on motorcycles, and even a few inches of extra piping made huge lag. Of course it's worse on a bike where the throttle is *really* essential to your steering.
Flamedx4 is offline   Reply With Quote
Old 09-06-2004, 03:46 AM   #3
instigator's Avatar
instigator is offline   Reply With Quote
Old 09-06-2004, 04:18 AM   #4
MvCrash's Avatar
Greetings,
I was always under the impression turbo lag was a result of how long it took the turbine to spin up. Today, with the light ceramic turbines and the really close tolerance bearings, I think lag was almost a non-issue now.
Gale Banks has a great site on turbos charging if you want some good information.
MvCrash is offline   Reply With Quote
Old 09-06-2004, 12:57 PM   #5
Foo Fighter's Avatar
the routing of the tube is scary going over the subframe just think if you crushed that out in the trail
Foo Fighter is offline   Reply With Quote
Old 09-06-2004, 01:25 PM   #6
934rnr's Avatar
Even better look how low the intake is try crossing some water with it. It might not be for everyone.
934rnr is offline   Reply With Quote
Old 09-06-2004, 02:30 PM   #7
roger's Avatar
The website doesn't have any useful info, so I can't tell exactly how this is supposed to work, but I tend to agree with Flamedx4 on this one. Having built a few turbo'd motors, my experience is you want less piping between the engine and the turbo, not more.
roger is offline   Reply With Quote
Old 09-06-2004, 02:32 PM   #8
superjoe83's Avatar
and the size of the turbo will determine the amount of lag also
superjoe83 is offline   Reply With Quote
Old 09-06-2004, 02:38 PM   #9
X-AWDriver's Avatar
$3500 price tag is a bit much for a product that may make your truck a bit difficult to off road with too,I'd just spend less and get a supercharger.
X-AWDriver is offline   Reply With Quote
Old 09-06-2004, 03:02 PM   #10
dbikeman's Avatar
They offer a snorkel for it.
dbikeman is offline   Reply With Quote
Old 09-06-2004, 05:14 PM   #11
Bumpin' Yota's Avatar
Turbo lag is a result of the a/r of the exhust housing, the trim of the turbine, the size of the turbine, and the size of the compressor wheel, I'd imagine that longer piping will slow spool up too.
The LONG piping there cant help, one does want HOT gas moving FAST hitting the turbine....however even with the heat and speed loss in the piping, you'd just reduce the a/r and keep a t3 housing most likely.... If I had to guess it's T3 at around .48 or so.... Im also betting the compressor wheel is moderately sized as well to reduce any lag. I can see it working; not as well as a conventional turbo, but better than NA for power, yes.
Personally I have a bad taste in my mouth for the TuRD blower after hearing about ALL of the problems....
Bumpin' Yota is offline   Reply With Quote
Old 09-06-2004, 07:55 PM   #12
zach34's Avatar
Yeah, I don't think it's for those of us who go wheeling(hopefully I'll get around to it one of these days).
Old 09-06-2004, 08:03 PM   #13
Sounds pretty interesting. I wonder if you can route the intake into the back cabin of the 4Runner? If it makes more power than the TRD supercharger with that configuration, it can't be too bad. Do you think that it will need the fuel upgrades like the supercharger? I think I would rather go this route than the supercharger because it looks like an easier setup.
havic is offline   Reply With Quote
Old 09-06-2004, 08:19 PM   #14
Co-Founder/Administrator
Staff
Corey's Avatar
On a Tacoma.
http://www.pnw4runners.com/temp2/turbo.jpg
Looks pretty cool if it does not get in the way while on the trail.
Corey is offline   Reply With Quote
Old 09-06-2004, 08:28 PM   #15
Guest
Quote:
I agree with you man. Not so much because it's an eaiser setup, but because it doesn't seem to have the problems that the supercharger has.
oly884 is offline   Reply With Quote
Old 09-08-2004, 01:25 PM   #16
Oly884, it looks like they gave us the foundation. If you can get someone to weld the turbo mount to the exhaust pipe, and route all the pipes yourself, I think you can get it done cheaper than the price they suggest. Again, I would try to mount my intake higher, in the back cabin, or something that will keep it dry.
Old 09-08-2004, 01:45 PM   #17
CynicX's Avatar
Quote:
Originally Posted by Corey
On a Tacoma.
hahah offroading with a turbo charged truck...that would be interesting.....picture this : You're climbing a steep grade and have no power because the turbo isnt spooled yet but it is interfering with the natural exhaust flow so you have less power in the low rpm range then before you got it....so your climbing and climbing and giving it more gas...nice and easy, nice and easy...then BAM here comes your additional 50 horsepower like a kick in the ass.....now your spinning wheels and in a crazy position...no thanks
plus think about it 90% of 4wheel low offroading is in the low rpm range....a turbo is useless in the low rpm range....if a turbo was a good idea offroad people would actually use them.....
I drove a 4 banger turbo charged jeep offroad and it was very scarey even on a moderate trail. I didnt feel safe enough to try it on the rocks because I was scared of the rush of power while being in a hairy situation. Even with the owner driving it was scarey and I think he was pretty scared too.
CynicX is offline   Reply With Quote
Old 09-08-2004, 01:53 PM   #18
CynicX's Avatar
that web page has a sorry comparison to the TRD supercharger.....they got 203 HP out of the trd supercharge
Old 09-08-2004, 01:59 PM   #19
Guest
Quote:
That did seem a little bit low for the TRD supercharger, but what's the average hp loss through the drivetrain on our trucks?
Old 09-08-2004, 02:04 PM   #20
CynicX's Avatar
this isnt a bad idea if you want something simple....but a turbo under the hood will have less lag and bigger power they say the HP goes from 140-220...which is pretty good for a simple install....80 HP
take the scooby 2.5 165 HP and put the sti turbo on it and you'll be running around 300 HP (with other upgrades of course, injectors, intercooler)....135 HP gain...
put a bigger turbo on a vehicle with the turbo up front you'll get more lag but bigger power....unlike the sts which is to far downstream to put anything bigger on....
in the video on the sts page it says the turbo condenses cool air and sends this cool air back to the engine...which is pretty odd considering when you condense air its gonna get really hot, this is what the intercooler on a car with a normal turbo is cooling, this hot condensed air...that makes the page kinda shadey too me....
I think I'd stick with the TRD supercharger.....
and dont get me wrong I'm not knockin this product, I just dont think its very useful for offroading and its webpage isnt very actuate....
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed justdifferentials Vendors Build-Ups (Build-Up Section) 12 09-12-2016 07:42 AM
WTT[International]: 22re Original turbo system shalom Engines - Transmissions 2 09-08-2015 11:02 PM
Need to find a mount pplusent 86-95 Trucks & 4Runners 9 09-03-2015 12:56 AM
Rear Shock Mounts - 89 Pickup Ryall 86-95 Trucks & 4Runners 2 09-02-2015 07:48 AM
Tags
22r, 46, 4runner, dohc, fj, mount, offroading, psi, rear, remote, required, sc400, turbo, walboro
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
