regear with stock factory locker ?
Nope. It just takes a different gear set than a factory open diff. You also have to disconnect the plumbing to the locker to remove the third, otherwise it's the same.
The Tacoma axle with the TRD locker uses a different gear set than the Tacoma axle without the locker.
Read more here: http://home.4x4wire.com/erik/diffs/#rear
These sections: "The T100/Tundra diff" and "Electric Locker".
I see. What you are saying is use 8" gears instead of 8.4. Got it. I read it to mean that they needed some sort of custom 8" gears. Now the real important thing (I think) is use V6 gears and not 4cyl gears and use a solid spacer instead of a crush sleeve.
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
jerusry
10-19-2015 05:28 PM
coffey50
07-28-2015 10:55 AM
