redline water wetter for 3.4l - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-28-2007, 05:02 PM   #1 (permalink)
how many bottles should i buy or need to put in?
jrock is offline
Old 11-28-2007, 05:13 PM   #2 (permalink)
fastkevman's Avatar
Not sure why or what you are trying to do.
I have had good experiences with a good system flush and fresh fluids.
My own past trials with WaterWetter have shown absolutely no improvement over what I already was experiencing with two separate vehicles, maybe others feel differently but, I wouldn't bother buying this product, I'd check my system for proper operation, just my two cents!
fastkevman is offline
Old 11-28-2007, 05:34 PM   #3 (permalink)
seanz0rz's Avatar
Send a message via AIM to seanz0rz Send a message via MSN to seanz0rz
it helped the overheating in my honda due to a beginning to fail thermostat. it was good enough until i sold it.
honestly, on a properly functioning cooling system, it is unnecessary.
__________________
1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Sonoran Steel #1, 285/75R16 BFG A/T, Elocker retrofit, Tundra calipers, brembo blanks, hawk lts pads, CarPC in custom center console with molded Indash touchscreen, KC daylighters mounted on Surco Safari rack, Custom sound system, 4xinnovation sliders, sleeping platform, Shrockworks front bumper, 1" 4crawler body lift, etc.
Pictures
Photobucket is being updated, if a picture i posted no longer works, please PM me.
seanz0rz is offline
Old 11-28-2007, 05:37 PM   #4 (permalink)
Texas_Ace's Avatar
Send a message via MSN to Texas_Ace Send a message via Yahoo to Texas_Ace
I added a version of that when i did my last flush. Not because i had a problem but just because i could. since i didn't have a problem before i can't know if it is doing anything now but i know that working at at least 3/4 power for a non-stop 500 miles towing a ~4000 - 5000 lb trailer. it didn't overheat at all. So tdo what you want, it costs a little but i don't see a reason to not do it.
__________________
Just call me TA
2000 Toyota 4runner Limited 3.4l V6 Auto SUPERCHARGED, URD 7th, 2.2 pulley, Doug Thorley Headers - My truck
All the Mods that can be done to 3rd Gens Thread
My thoughts on Gun control summed up quite nice:
Quote:
Originally Posted by sdstud212001 View Post
Guns kill people like spoons make people fat
Quote:
Originally Posted by Dare44 View Post
Im a firm believer in the saying "If you outlaw guns, only the outlaws will have them"
“Gun control runs aground on this simple fact: people who would use guns to break laws would also break laws to use guns”
Texas_Ace is offline
Old 11-28-2007, 05:47 PM   #5 (permalink)
im super charged etc., and some of the guys are using it...anything to keep temps down is worth it to me---not sure of actual test data though?
jrock is offline
Old 11-28-2007, 07:41 PM   #6 (permalink)
4Crawler's Avatar
One bottle is probably fine, that is what I use in my 22RE. If your cooling system is in good working order, you won't see any temperature change. Why? Because it is the thermostat that controls the engine temp and the water wetter won't change the setting of the thermostat. Also, if you have a problem with the cooling system, it probably won't fix it, either. I run it both to reduce cavitation and hot spots inside the cooling system and also hopefully it'll help a little if something were to start to go south while on the trail or road. One time I had the fan clutch lose all its fluid in 100F temps in stop-n-go traffic. Temp gauge went up a little bit but did not overheat. In fact did not even know anything was wrong until I popped the hood a week or two later and say the silicone oil splattered all over the underside of the hood (what a mess!). I figure between the water wetter and the new 3-row radiator, that saved the engine that time.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 11-28-2007, 08:52 PM   #7 (permalink)
j-man's Avatar
Quote:
did you put in the 170 degree t-stat? that'll keep your temps cooler than the stock 190 degree.
__________________
2000 4Runner v6 sr5 4x4 5spd: Turbo'ed
99 4Runner v6 Sr5 4x4 5spd: Saw's / OME combo TrueTrac rear
98 4Runner V6 Sr5 4x4 5spd E-locker: Saws / OME combo... EEZI AWN Roof Tent 1.4m
97 4Runner V6 Sr5 4x4 Auto: Saws / OME combo TrueTrac rear
2003 Landcruiser 285 BFG At's and outback roofrack
My Baja Trailer Build: http://forum.ih8mud.com/showthread.php?t=179520
http://community.webshots.com/user/bajaroadtrain
j-man is offline
Old 11-29-2007, 06:29 AM   #8 (permalink)
X-AWDriver's Avatar
1 bottle is enough and I used in my very modded Eclipse and with my datalogger that read everything right from the ECU my coolant temp stayed over 10 degrees cooler consistently with a bottle of Waterwetter in it.
__________________
'99 4Runner Highlander 4wd
E-locker,rear diff and deckplate mod * 265/75/16 Nitto TerraGrapplers * Yakima Load Warrior rack * clear corners/signals * Tacoma skidplate * Silverstar lamps/fogs
Alpine CDA-9831,Bazooka EL Series 250w amp,MTX 10" sub
X-AWDriver is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Redline? algranger 86-95 Trucks & 4Runners 21 09-27-2007 06:51 PM
GS Redline 4-RUNNIN' FREAK Vehicle Audio & Home Entertainment 2 02-01-2006 05:12 AM
Water Wetter & Purple Ice ElwayLite 95.5-2004 Tacomas & 96-2002 4Runners 6 02-29-2004 07:52 PM
Redline MT-90 jrallan26 95.5-2004 Tacomas & 96-2002 4Runners 1 04-26-2003 04:04 PM
"New" Mod idea - Redline water wetter rimpainter.com 95.5-2004 Tacomas & 96-2002 4Runners 11 04-21-2003 07:22 AM
2009 InternetBrands, Inc.
