Rebuilding 3.4
Old 06-02-2014, 11:46 AM
Machtac's Avatar
Rebuilding 3.4
Just bought a 99 taco with 205k on the dash. My plan is to build a nice off-roader that handles the highway nicely. I want to eventually lift it and stuff 35's under it. First of business will be to pep the engine back up to make it safe. I want to pull the engine and put some new internals in to keep it from blowin on me with over 200k miles. Then I want to slap a TRD supercharger/intake/exhaust on it. My question is..what should I do to the engine to keep it bulletproof? I would like to have the engine built and supercharger ordered or installed and tuned by September˟
Im new to yotas and the 3.4l so I dont know its weak spots or what is normally needed with so many miles
Old 06-02-2014, 11:48 AM
JasonYota's Avatar
You would probably be just fine doing a regular tune up and change the timing belt and water pump.
Old 06-02-2014, 03:26 PM
Machtac's Avatar
So the internals should be able to handle the extra power that the supercharger dishes out?
Old 06-02-2014, 03:37 PM
JasonYota's Avatar
I would imagine since some come stock with the supercharger.
Old 06-02-2014, 03:41 PM
Machtac's Avatar
Wow, didn't know that..
I guess i'm just worried because of the 200k miles...but "if it ain't broke, don't fix it," right?
Old 06-02-2014, 03:48 PM
JasonYota's Avatar
Probably the supercharger your were going to order is a factory one. If you've researched them yet
Old 06-02-2014, 04:49 PM
Machtac's Avatar
Yes I have done some research. It will be a TRD OEM supercharger. I will also be getting the URD 7th injector kit for the fuel upgrade to help with pinging. Then a 2.2 pulley i believe is another recommendation. I'm not sure what the "IPT Valve body upgrade" is though? Is that only for automatic tranny's?
Old 06-03-2014, 02:44 AM
Texas_Ace's Avatar
Yes, leave the engine alone, they regularly turn 300k-400k miles. They are tanks that refuse to die. They will also take a TON of abuse, more then the wimpy TRD superchaerger can put out thats for sure.
If you want some real power/performance go turbo.
The stock engine is good to north of 400whp, how far north depends on how you are tuning it and whats making the power.
Old 06-03-2014, 04:19 AM
Jomoka's Avatar
If you were really going to go wild with boost, you'd probably want some H-beam rods and forged pistons. And a cam.
But really, all you really need to do is a t-belt/wp unless it's had one recently.
The good thing about thrashing a bone stock engine is that if you blow it up, another one is really cheap and easy to find. Blowing up a $$$$ set of custom rods and pistons really hurts.
Old 06-09-2014, 07:51 AM
BlazeRunner's Avatar
How to keep the 3.4 bulletproof?
Maintain it.
Jayboy74
10
12-21-2021 08:27 AM
pplusent
09-18-2018 10:02 PM
coleypull15
11-03-2015 07:41 AM
93toyoguy
08-31-2015 08:02 AM
ashersullivan88yota
08-19-2015 06:00 PM
Quick Reply: Rebuilding 3.4
