Rear Window Question
I was trying to fix my rear window. I check the quick connects and the bolts that hold down my cap. They all seemed fine but when i opened up the tailgate, I saw this plug.
so what does this connect to? is the plug used at all?
I also had a question on what should be in this missing spot here.
picture #1: i think it's the part the plugs into the key switch on the back. does the key work to put the window down? if not, then that's probably the problem. at least that's the only round plug i ever saw in my tailgate
picture #2: that's the 'clutch start cancel' button in a manual. but from the picture, it looks like you have an auto. i don't know what if anything is there in the auto.
You need a new rear window motor? I have one, just let me know.
Your picture #2, on my 85 there was a blank there. I put a fog light switch in it. The clutch start cancel first came along around 86ish (if my CRS isn't acting up) and it went in that spot.
yeah it's an auto.
Originally Posted by backfrog
yeah, the key doesn't put the window down. what do i connect it to? i don't see any plugs in the tailgate that would fit. i did see this yellow wire that i think the previous owner put in but that doesn't lead up to anything.
yeah it's an auto.
yeah it's an auto.
there may be a way to take off the black plastic that says "toyota" on the outside of the tailgate. i couldn't figure it out, but if you can get that off, it should make things a bunch easier.
06-01-2021 01:51 PM
rushw
07-18-2015 01:46 PM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
