Rear window down problem
This is strange...
I have a 2002 SR5, no alarm. I bought a new keyless entry remote, and programmed it. The rear window down button on the remote works fine.
But now the rear window control on the dash does not work. I can still raise and lower the window using the key on the liftgate.
Any thoughts?
Thanks - Bob
Any thoughts?
Thanks - Bob
I'm an idiot!
Bob K - Thanks.
I must of hit the window lock button this morning when I programmed it. I actually never knew the window lock button affected the rear window.
Bob K - Thanks.
I only found out because my wife hit mine and the next time I drove it I used the remote to lower the window and tried to raise it with the switch and it would not go up. At first I thought the motor was bad or something till I tried the key and it worked. Checked the lock button and when I turned it off it worked. When the lock is on the drivers window is the only one that goes up and down.
Don't feel bad..
I remember over on 4x4wire a couple of years ago someone had he same problem and wound up tearing the who system apar rying to find the fault.
06-01-2021 01:51 PM
icentropy
07-11-2015 07:21 AM
Jnkml
07-06-2015 01:20 PM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
