Rear window
Rear window
I have 92 4runner and just had the rear regulator replaced. The guy at the body shop said to keep the gears clean of gunk. But never said how or what to use to clean it and the relube it if need be..I was wondering if any of you had experince with this?
Originally Posted by Godzilla
What does the rear window regulator do? and what were the signs that indicated it needed to be replaced?
Just use white grease (not lithium grease) or multi purpose grease. Grease up the teeth on the regulator and the window tracks (just the bottom one). I used the white lithium grease and its a pain to clean when you finally realize that you have to fix or replace a part in there.
Are there any write-ups on taking the tailgate apart, what/where to lube etc?
I always learn more by pictures than words so I hope there is a write-up.
Thanks,
Jason
Thanks,
Jason
Well I thought I explained it ok....but look at this site....page 6 is a perfect picture that will answer all your questions on lubing up the window.....and your welcome
http://personal.utulsa.edu/~nathan-b.../3frontdoo.pdf
I just pop the carpet board off and use an oil can. This seems to be the cleanest way to go about it. I lube the gears, the conector arms, and anything else that moves.
06-01-2021 01:51 PM
sabine
07-18-2015 03:59 PM
icentropy
07-14-2015 10:23 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
