| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Rear Sway Bar Bushing Popped Out
__________________
Yes, I said "country." America really is a nation, but you couldn't convince those who lead the Democratic and Republican Parties of that. Both parties now see America as nothing more than an economy, a marketplace, and not a sovereign nation. They don't see you and me as citizens of this great nation; they see us as units of labor, consumers and taxpayers. Yes, I am here to collect my 238$ worth of stock from AIG. "What do you mean a free market economy doesnt apply to the rich?" |
#2 (permalink) |
Mine used to do it all the time. I just removed the entire rear swaybar assembly. If you don't want to do that, order a set of front endlinks and put them on the rear. The fronts are longer and won't be as prone to snapping.
__________________
99 4Runner 4x4 3.4 5 speed E-Locker SAW 2.0 Coilovers LC coils and shocks 1" 4 Crawler Body Lift 1" Diff drop SS adjustable trac bar Addco front/rear sway bars 285/75/16 Maxxis Bighorns |
#3 (permalink) |
thought i was smoking crack or something-i am suprised not hear the prob with other wheelers. THanks
__________________
#4 (permalink) |
I have had one split apart and fall out once but never had one just pop out. Weird.
__________________
-Marcus 1997 4Runner Limited 4x4, E-Locker, Bilstein HDs, Air Springs, Deckplate Mod, 265/75/16R Bridgestone Deuler A/T Revo |
#5 (permalink) |
I've never seen or heard of this problem.
Anyone have a picture to post? |
#6 (permalink) |
I just re-read the post and realized that I may have been referring to a different problem that I have experienced.
I have actually never heard of or experienced a swaybar bushing falling out of the bracket. I have experienced and heard of others experiencing their rear swaybar endlinks snapping or pulling through the mounting bracket. Sorry if my first post was misleading.
__________________
#7 (permalink) |
Put some Polyurethane bushings and brackets, in place of the stock ones and you'll have no problem with them slipping out, and as said above longer end links will help!!
I'm running these on both front and rear sway-bars> ![]() And I've built myself a set of Heavy Duty end links>
__________________
1997 4Runner Limited; 3.4L 4WD; Rear E-Locker; OEM/Sonoran Steel 3.5" Lift; ARB Tacoma BullBar w/ 525 PIAA Dual-Beam Lights; Alpine/JL Audio; CompuStar; TRD Headers w/ Magnaflow custom dual exhaust; 305/70 XTerrains on Blacked-out A/R wheels; Tundra Brakes; 4" Deckplate mod w/ TRD filter; ISR mod; Yellow Top Optima w/ custom tie down; Custom grille inserts; JDM Black headlights w/ 6000k HID's; Extended diff breathers PICS> ::97 4Runner Site:: |
#8 (permalink) |
So, this is almost like a newbie question--but do ya'll run disconnects on the rear or just longer links. Any benefit from running disconnects in the rear?
__________________
#9 (permalink) |
I don't run a swaybar at all in the back. Longer endlinks will allow the rear swaybar more range of motion as the axle flexes. Discos will allow you to disconnect the swaybar before wheeling preventing snapped endlinks. There's benefits to both I'd just rather not have to worry about it.
__________________
#10 (permalink) |
With my current lift set up, mine are just asking to snap at any momement.
__________________
1999 Toyota 4Runner limited 4x4,BFG's 285/75/16's. Land Cruiser wheels. 2inch 4crawler BL, Factory Locker, 4inch ProComp front IFS lift, front LC coils on the rear with LC shocks. Original owner.18-19-mpg highway. 2007 Dodge Mega Cab 4x4, Mineral Gray, 5.9L Cummins. SMARTY JR, Mufler delete, Silencer ring MIA, SIRIUS. PICTURES OF RIGS http://community.webshots.com/user/roofgoof Owner of 1970 Pontiac GTO JUDGE |
#11 (permalink) |
eh, swaybars are over-rated, just take it off
__________________
. . . I said lie, for me lying under a process tree . . . . |
#12 (permalink) |
There is no real benefit to disconnecting the rear sway-bar on a 4Runner!! Its been tested that you will only get about 1" more wheel travel with stock length end-links as to not have'n it connected!! And the same results were seen for the front sway-bar!! If you run your Runner more on-road then off-road, IMO your better off keeping your rear sway-bar!!
__________________
#13 (permalink) |
I've had the bushing pop out as well, I've never heard of using from discos on the rear, but seeing as how i have an extra set (took out front sway bar), I will definitely give this a try
__________________
Rob 1999 4Runner Limited 4x4, retrofitted e-locker/ ARB front locker with 4.88 Precision Gears, Tundra/LC lift, 2" 4Crawler BL, Nitto Mud Grappler 35's on 16x8, Marlin sliders, TJM T-15, Warn M8000 w/ synthetic line, Mad Mike's custom rear Bumper, deckplate and ISR mods, Vortex Muffler, custom made tube doors pictures here I support Banned Neliconcept |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| sway bar bushing replacement? | wormhole | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 06-25-2007 09:06 PM |
| Installed front and rear sway bar bushing....... | 2000t4r | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 01-25-2007 05:20 AM |
| Sway Bar bushing replacement | TheDarkKnight | Newbie Tech Section | 6 | 06-23-2006 12:17 PM |
| Bushing-27mm Sway bar | Zo | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 03-09-2005 05:40 PM |
| Rear sway bar bushing trouble | outlaw27 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 05-11-2004 07:33 AM |
