Rear Storage Compartment?
Old 07-03-2009, 06:00 PM
trollcruiser's Avatar
My dad just added a 1999 4Runner Highlander to the collection. We were looking at the rear compartment on the inside and had a question. There are two straps and a formed indentation. What went here in stock form?
Thanks!
Old 07-03-2009, 06:52 PM
neilan's Avatar
jack?
Old 07-03-2009, 09:32 PM
Godzilla's Avatar
It is to hold the warning reflector kit. This kit however was not included as original equipment.
Old 07-04-2009, 08:57 AM
scuba's Avatar
My dad uses it to hold a car vacuum
Old 07-04-2009, 09:09 AM
Staff
DeathCougar's Avatar
The jack kit goes under the rear seats, but most people often mistake that as a place for the jack to go. I supposed you could put it there, but its the wrong place.
Godzilla got it right, its for the reflector kit. You could put whatever you want in there though, but its not rated for much weight.
Old 07-04-2009, 10:33 AM
Rock Slide's Avatar
It's similar to this:
Old 07-04-2009, 01:42 PM
Parker Runner's Avatar
SKS/AK 67 broke down.
Old 07-04-2009, 07:36 PM
scuba's Avatar
Best idea yet..
I going to be that was a factory option in the middle east
Old 07-05-2009, 08:48 AM
SLOMatt's Avatar
The compartment also happens to be the perfect size for a 30' tow strap, receiver shackle, first aid kit, and a pair of gloves.
- Matt
Old 07-05-2009, 01:49 PM
Rich_O's Avatar
I like the rifle idea too.
I think I remember reading in the OM or FSM about an optional reflector set like the one pictured. I've seen those reflectors pretty consistently in airport shuttles, rented trucks, etc. I'd guess it's a requirement for commercial vehicles since it's so consistent. At least in CA.
Here's what I put in mine. It's always nice to keep more floor space available for heavier stuff by mounting lightweight things up on a bracket.
Like the man said, 30' towstrap. The green med pouch has epoxy and other small repair items. It looks a little precarious, but it really does stay put. The larger green thing is a cheap Czech army surplus shovel. Small enough to pack, but I'd prefer a full sized shovel on an extended trip, or a trip in difficult terrain.
Rich
Old 07-05-2009, 03:34 PM
Drgoodspd's Avatar
I keep a tow strap, bungee cordz, fix-a-flat and climbing rope. E-tool also kept in the rear of the truck.
Old 07-05-2009, 04:23 PM
fasthorse67's Avatar
That's funny. I always wondered what that was for. I have a tow strap and jumper cables in mine.
Old 07-06-2009, 09:03 PM
Thanks guys. That is what I thought, just wanted some verification and make sure something wasn't missing.
Old 07-13-2009, 08:20 PM
TheDurk's Avatar
My Brazilian Hi-Lux has the same cubby and the reflector comes stock. Brazil requires reflecting triangles in all vehicles, as do many other countries. You also get a neat little fire extinguisher under the front seat. This goes back to when half the cars in the country were VW Bugs whose air-cooled engines liked to catch fire in tropical heat.
Old 07-14-2009, 07:35 AM
Ritzy4Runner's Avatar
Was wondering about those straps myself, but if you have a 96-98 4runner (gen 3 flight 1) then you have a tiny stowage compartment that won't have those straps BUT ... I did the mod and show you how to do it! Check out my install here: https://www.yotatech.com/forums/f2/m...runner-180108/
Old 07-14-2009, 11:26 AM
Guest
4x4mike's Avatar
I used an air body saw to cut out all the indentions for more room. I wasn't going to use the straps anyways and now I can fit a 2.5 pound extinguisher, real 30' tow strap, gloves, couple flares, shackles and hitch pins. The plastic box compartment is plenty stiff to do without the inner mouldings.
SMOD
07-27-2015 01:45 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
rushw
07-18-2015 01:46 PM
icentropy
07-14-2015 10:23 AM
skoti89
07-08-2015 12:05 AM
Quick Reply: Rear Storage Compartment?
