Rear springs keep shifting
I have been searching for a few hours now and i cant find it i just got my toytec lift installed and was wondering if anyone has a limiting strap on there rear diff to keep there rear springs from falling out of place when flexing? i have the toytec 3 in lift with the bilstien shocks in the rear its a 97 4runner 4x4
thanks
thanks
You won't need limiting straps on the rear, your bumpstops shouldn't allow the springs to get loose in there. Did you get longer shocks to accomodate the lift?
I have the same lift with stock shocks and have had mine completely flexed out and the rear springs stayed put.
I will take a wild guess that you installed them upside down. Both sides will fall out of place or just one side?
Hope I am wrong but someone should be able to just look at it and tell, so share a photo if you dare....
Check this out:
http://www.sonoransteel.com/rear
It has some good photos and info on limiting straps.
BeMiceElf
10-10-2015 09:40 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
crashburnoveride
07-10-2015 06:39 AM
