| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Rear Seals Again!!!!! - Need Advice
__________________
96 Runner SR5, 4x4 97 Volvo 850 GLT "Rice Killer" |
#2 (permalink) |
Convert the rear to discs and be done with it
__________________
1996 Black 4Runner V6 5 speed 4X4| Retrofitted E-Locker| SAW's| LC coils and Doetschtech shocks| ATS arms | 285 Goodyear MTR's|TJM T-15 With Warn M8000|Retrofitted Toyota Hood Scoop| Stubbs Sliders|Bushwacker Extend-A-Fender Flares| Extended rear diff breather| Uniden 510XL CB w/ 4 Ft. Firestik II Antenna|Dynomax Super Turbo Muffler|Black headlights and corners| More to come... 2007 VW GTI 6 Speed |
#3 (permalink) | |
Re: Rear Seals Again!!!!! - Need Advice
Quote:
A housing is about 500 bucks online and an axle is about 230 online, bearing is about 35, abs rotor about 20, both seals about 12, retainers 11 each (need 2), snap ring is about 1, and then new studs are about 3 each, brake backing plate is about 70, brake shoes are about 30, bearing cup flange is 40, 4 serrated studs for bearing cup flange are about 2 each. all are the online prices I paid when I replaced the whole drivers side axle assembly with the updated parts ("updated" by toyota but they still claim there is nothing wrong with the original design, HUH!!) and they can't say it's the guy doing the work (me) because they did the drivers side 5 times before I did it another 2 times. do a search, this topic has been touched on here before alot.
__________________
Front: 4.88's w/ ARB Locker Rear: 4.88's w/ ARB Locker Lift: Suspension - F: Sway-A-Way Coilovers; R: OME Coils/Shocks Body - 2" HDPE Pucks w/ higher strength bolts Recovery: TJM T15 Bull Bumper w/ Warn M8000 Winch Lighting: Lightforce Striker 170's Multimedia: Kenwood DNX5120 DVD/GPS/USB/iPod/SAT Sound: Focal 165A1 Component Front w/ Focal 130CA1 Rear Infiniti Kappa Perfect 10.1 Sub 500W RMS amp for fronts and rears; 500W RMS amp for sub Power: Optima Blue Top 1400 Watt Power Inverter |
#4 (permalink) |
Surely you guys aren't going to the same mechanic right?
Chris |
#5 (permalink) | |
Quote:
there's a tolerance for this so the seal sits on the retainer. I believe that's my prob with the pass side since I measured it when I replaced my third a couple months ago. I knew it was off but I didn't have time or the retainers to rebuild that axle. It may just be Joe Meyers Toyota here that can't do things right but I do my own work from now on, it's cheaper and a whole lot more fun.
__________________
Front: 4.88's w/ ARB Locker Rear: 4.88's w/ ARB Locker Lift: Suspension - F: Sway-A-Way Coilovers; R: OME Coils/Shocks Body - 2" HDPE Pucks w/ higher strength bolts Recovery: TJM T15 Bull Bumper w/ Warn M8000 Winch Lighting: Lightforce Striker 170's Multimedia: Kenwood DNX5120 DVD/GPS/USB/iPod/SAT Sound: Focal 165A1 Component Front w/ Focal 130CA1 Rear Infiniti Kappa Perfect 10.1 Sub 500W RMS amp for fronts and rears; 500W RMS amp for sub Power: Optima Blue Top 1400 Watt Power Inverter Last edited by keisur; 11-11-2003 at 08:57 PM. |
#6 (permalink) |
I took mine to a shop, and he charged me $87 in labor plus parts, which I bought first. It hasn't failed yet, and I probably have about 10K miles on them with some serious off-roading two times a month too.
Chris |
#7 (permalink) | |
Quote:
I paid a local dude to "set-up" the axle for me the first time I did it myself and he ended up using a blow torch to burn/melt/cut the bearing off the axle and out of the cup, and used a fiberglass bar and sledge hammer to beat the ABS rotor off and a sawzall to cut the retainers off. in the process of this obviously incorrect procedure he managed to bend my axle so that is why I replaced it and bought a cheap press to do it all myself. I still have the axle sitting next to my press to remind me of why I don't trust anybody with my runner. Again though, I don't want to pay somebody to do something I can do. but that's just me, I enjoy the work, hehe.
__________________
Front: 4.88's w/ ARB Locker Rear: 4.88's w/ ARB Locker Lift: Suspension - F: Sway-A-Way Coilovers; R: OME Coils/Shocks Body - 2" HDPE Pucks w/ higher strength bolts Recovery: TJM T15 Bull Bumper w/ Warn M8000 Winch Lighting: Lightforce Striker 170's Multimedia: Kenwood DNX5120 DVD/GPS/USB/iPod/SAT Sound: Focal 165A1 Component Front w/ Focal 130CA1 Rear Infiniti Kappa Perfect 10.1 Sub 500W RMS amp for fronts and rears; 500W RMS amp for sub Power: Optima Blue Top 1400 Watt Power Inverter Last edited by keisur; 11-12-2003 at 07:06 AM. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Rear Axel Seals | SwampThing | 86-95 Trucks & 4Runners | 2 | 03-18-2007 08:18 AM |
| rear axle seals | tyndalltoy | 86-95 Trucks & 4Runners | 11 | 02-11-2007 08:48 PM |
| rear axle seals and bearings. | jonwanner | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 06-01-2006 10:55 PM |
| Leaking rear axel seals, rear bearing slop | TahoeEd | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 12-15-2004 09:53 PM |
| Need help with rear axle seals | David | 95.5-2004 Tacomas & 96-2002 4Runners | 36 | 09-09-2003 08:07 AM |
