rear output flange leak
Old 01-22-2005, 05:22 AM
brendonv's Avatar
ive got an 87 pickup, i recently installed the all pro transfer case mounted e brake, when i took the rear output flange out, there was some RTV on the nut, when i installed it back on, i didnt use any, now there is a small leak coming from it...is it OK to use RTV?
thanks
Old 01-23-2005, 05:29 PM
brendonv's Avatar
T O P
Old 01-23-2005, 06:36 PM
4Crawler's Avatar
The RTV is used to seal the splines from oil. There is also an oil seal inside the t-case that rides on the outside of the flange. See if you can find where the leak is coming from (inside around the nut or outside) and fix the source.
Ladythump
22
11-09-2015 08:53 AM
redneck17
10-29-2015 09:09 PM
Iceman4193
07-15-2015 04:48 PM
andrewtexas123
07-14-2015 04:29 AM
Avenged
07-09-2015 07:55 AM
Quick Reply: rear output flange leak
