Is This The Rear Main Oil Seal?
Old 11-12-2007, 07:38 AM
BajaRunner's Avatar
I'm pretty certain this leak is starting here, not NOT coming from above from the valve cover. I think I have a very light leak coming from the valve covers, but, it does not account for how much oil I am leaking (10 drops a day now!!!).
If its the rear main, I'm pissed, it will be a lot of money to spend ($1k at least).
First shot is from the passenger side wheel well. Second shot is underneath, looking forward towards the front of the car.
Any info please?!
Old 11-12-2007, 08:06 AM
Ringmaster's Avatar
Yep the rear main is leaking. Replace it yourself and save alot of dough!
Old 11-12-2007, 08:07 AM
Ringmaster's Avatar
The rear main seals the crankshaft to the block. It isn't between the block and bellhousing as in your pic.
Old 11-12-2007, 08:19 AM
CTRJ's Avatar
Not sure if yours is a 5 speed, but if it is it's behind the clutch. That means you have to drop the tranny and pull the clutch just to get access to it. It's a bit of work to get it done.
Old 11-12-2007, 08:22 AM
mikes19984x4's Avatar
yeah, i've got a small leak in the same area as you...planned to get it fixed over Christmas break (i'm in college right now). but how much does a fix like this normally run? and CTRJ, how are those nittos that you're running, as i'm lookin into those for my next set of tires...
Old 11-12-2007, 08:36 AM
jagger_snitt's Avatar
When you replace the rear main seal it is a good time to check your T/o bearing(throw-out bearing) and your clutch condition. When I needed a new clutch in the 88' I installed a new rear main seal(it was leaking) centerforce t/o and centerforce II clutch,and factory flywheel.By the way getting the trans in position is a pain in the sack without a trans jack or adapter for regular jack. Good luck!
Old 11-12-2007, 09:20 AM
toy power's Avatar
the first thing i always do when trying to find an oil leak is pressure wash the whole area. its very difficult to isolate a leak when there is as much oil everywhere as whats in your pics. you might be surprised at what a valve cover can leak, and it will all accumulate at the bell housing.. so definitely investigate some more before freaking out over your main seal. and i will laugh at you if you pay someone $1000 to fix a main seal... do it yourself, it will put some proverbial hair on your chest.
Old 11-12-2007, 09:33 AM
mt_goat's Avatar
If you end up dropping the tranny one of these will be your best friend:
(hairy chest sticking out)
Old 11-12-2007, 10:58 AM
CTRJ's Avatar
Taking the tranny out of a 4runner is a PIA, even with a good jack. You might as well do your clutch while you're at it since you're right there. I don't know that I would try to do this if you don't have access to a lift. Doing it on the floor would suck big time!
Old 11-12-2007, 10:59 AM
CTRJ's Avatar
I love them. They do well in sand and the rocks and on the street. I would recommend them to anyone!
Old 11-12-2007, 11:13 AM
BajaRunner's Avatar
I took it in to my friend who is a mechanic at a dealership, he said that its a lot of work to drop the tranny. I don't know if I have the patience to do this by myself.
Well, I'll be replacing the valve cover gaskets this weekend since I have a small leak there anyways. Maybe it is the root of the problem? Who knows..I'll see.
Who here has done a rear main seal on their 3rd gen? I've only got 115,000 on my truck.
Old 11-12-2007, 11:14 AM
BajaRunner's Avatar
How bout I give you a 12 pack and some steak if you come over and work on it for me?
Old 11-12-2007, 11:16 AM
thanks man. btw, how many miles have ya put on them and with that many miles, how much tread is left...i know, a lot of questions, but i like to do some research b4 spending that much $. thanks man...
Old 11-12-2007, 11:20 AM
mt_goat's Avatar
Only if the top 2 bolts are stuck, lol. Once they are loose its not that bad.
Old 11-12-2007, 11:47 AM
ARB1977's Avatar
Maybe try some maxlife oil that contain seal swellers or do a auto rx treatment. It may help or stop your seal from leaking.
Old 11-12-2007, 11:48 AM
ARB1977's Avatar
Just courious how many miles do you have?
Old 11-12-2007, 12:26 PM
J-Ball's Avatar
Same problem with the 2000 4runner I just bought. I was quoted around $400 to fix. The same mechanic said that unless it's gushing not to worry about it. He said even a new seal would most likely leak as much as what I've got now. I'm going to try a seal swelling type of oil or oil treatment and otherwise forget about it untill it's gushing. Anyone have any good luck with stop leaks etc?
J-Ball.
Old 11-12-2007, 02:41 PM
BajaRunner's Avatar
Well, Im running Castrol GTX high-mileage, and 1 quart Lucas Oil Additive...(its like molasses). I thought that would help. Nope.
Whats funny is that when I switched to synthetic, the oil started leaking EVERYWHERE. It was ridiculous.
I have about 115,000 miles on my truck BTW.
Old 11-12-2007, 05:00 PM
mt_goat's Avatar
When I switched from Castrol Syntec to Mobil 1 my BMW oil pan gasket started leaking too. I think the Mobil 1 cleaned away some sludge that was keeping it from leaking.
Old 11-12-2007, 06:17 PM
BajaRunner's Avatar
Yeah, I agree. I also think synthetic is just a little bit "thinner" in ways. I used the amsoil engine cleaning product before I switched to syn. Bad idea... it cleaned out all the sludge!
Quick Reply: Is This The Rear Main Oil Seal?
