Rear Locker Mod? Need Info Fast...!!!
Old 04-19-2004, 01:49 PM
SandSman783's Avatar
Exclamation Rear Locker Mod? Need Info Fast...!!!
Hey what's up fellas,
Hey I just did the rear locker mod (grounding the red/blue wire from the ecu) so that the locker can be engaged in 2wd, 4 high and low. But I want to make sure everything is now working correctly. Is there a test I can do to see if it's working? I drove the truck after grounding the wire. I engaged the button while at a stop (tried in 2wd and 4wd high and low) and the "rear locker light" on the dash just kept flashing. Does that mean (since it did not go on and stop blinking) that I did something wrong and it won't engage now (or is it always engaged now and won't un-engage)? I need advice and help here pretty fast fellas. Any help would be greatly appreciated. Thanks in advance guys... -Keven
Old 04-19-2004, 04:32 PM
L33T35T 4Runner's Avatar
i thought it was a grey wire... not blue
Old 04-19-2004, 06:08 PM
Billf6531
Guest
Posts: n/a
As long as you followed the instructions here: http://www.hboss.net/4runner/locker_safety.htm it should work. Are you sure you grounded the wire towards the ECU and not the end of the wire disappearing into the wiring harness? If you did everything correctly, try driving slowly in an S shape in order to allow the locker parts to line up and lock.
Old 04-19-2004, 06:18 PM
toy283's Avatar
If you're stationary and try to engage the locker, it may flash constantly if the splines aren't lines up. As stated above, you need to move in a gentle curve to line everything up and then it should fully engage and the light go on continuously.
Old 04-19-2004, 06:29 PM
Angry
Nah, it's definitley the blue/red wire. I hooked it back up the way it was and everything still works (it locked fine after splicing it back into the ecu). My ground was goodwhich is why I don't understand why it didn't work. I tried engaging the locker from a stop in 2wd, and all the possible combinations of 4wd. And each time got nothing. I hooked it back up, put it into 4low and the locker locked up immediately without having to zig-zag or do anything else. So once again I'm puzzled. :wtf: But if anyone has any more ideas, I'm more than willing to try them, otherwise it's goin back to stock and only being able to be engaged in 4low. Thanks again fellas.... -Keven
jerusry
10-19-2015 05:28 PM
Daneums
08-20-2015 05:36 AM
icentropy
07-11-2015 07:21 AM
Nickdigg
07-07-2015 06:04 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Rear Locker Mod? Need Info Fast...!!!
