rear lift springs
Old 04-22-2003, 02:43 PM
Guest
oly884's Avatar
rear lift springs
The blocks are getting really annoying on my truck and I'm looking to get some 4 inch lift springs for the rear. what do you suggest?
Old 04-22-2003, 02:49 PM
joshik's Avatar
if you are on a tight budget (as in my case) go with the DOWNEY springs. they are the same spring rate as stock. however, they are 3" lift springs ($150 for the pair).... but i got the extended shackles that give approx 1 1/2 " lift ($40 for the pair). they dont recommend getting the shackles with the lift springs, b/c they said it sacks them out faster... but i did it nehow... it works. it sacked out a bit, but its ok.
otherwise, go with ALL PRO or AOR .
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
88sasturbotoy
08-11-2015 01:56 AM
coffey50
07-28-2015 10:55 AM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: rear lift springs
