Rear Lift Question
Old 08-09-2003, 03:17 PM
koyota93's Avatar
Rear Lift Question
Does anyone know if 285-75-16 tires will fit in the rear of a 96 4wd 4runner, using stock springs? I'm getting the Fox coilovers this week. It is from a Tacoma so there is nothing to lift the rear. I don't want to put springs in unless I have to. Does anyone know what the minimum amount of lift I would need, if it doesn't fit? I don't want it to sit stink buged [higher in the rear than the front]. Any help would be appreciated.
Old 08-09-2003, 05:38 PM
ravencr's Avatar
They' probably fit unloaded, but when you hit bumps and have any flex in the rear when off-roading your screwed. You need a minimum of 2" lift to fit them.
Chris
Old 08-09-2003, 05:39 PM
RTdawgs's Avatar
prob will fit, but you might slam the fenders when the suspension travels.
06-01-2021 01:51 PM
akaphilly
07-09-2015 02:18 PM
87turboPA
07-09-2015 05:58 AM
God's Bounty Hunter
07-08-2015 12:54 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Rear Lift Question
